Trouble Using "unicode" in Python Scripts after Upgrade
Thu May 12, 2022 7:37 am
SearchCz offline
Running MacOS Montery 12.0.1 and Indigo 2022.1. My embedded scripts are throwing error messages about "unicode".
When my script says:
indigo.variable.updateValue(1376345918,value=unicode(0))
The event log complains:
Script Error embedded script error:
Script Error name 'unicode' is not defined
embedded script, line 63, at top level
NameError: name 'unicode' is not defined
I'm in the process of sifting through my scripts for similar references and making this change all over the place. Is there an easier solution?
Thu May 12, 2022 7:59 am
Re: Trouble Using "unicode" in Python Scripts after Upgrade
Nope. You need to change ‘unicode’ to ‘str’ in all your scripts. Just one of the many changes in Python 3.
Thu May 12, 2022 8:52 am
SearchCz offline
Any trick to finding all the occurrences of "unicode" in my scripts? Like a global search ?
Thu May 12, 2022 9:12 am
Well, you could make a copy of the Indigo database file, then search that for the string. You’ll have to decipher the XML around the scripts to figure out what schedule/trigger/action group it’s in. Or you might be able to tell from the contents of the script.
Sat May 14, 2022 4:08 pm
SearchCz offline
Turned out easier to run every script and look for error messages. Not even a big deal to do, and everything seems to be running smoothly now.
Sun May 15, 2022 10:52 am
[MODERATOR NOTE]: moved to the Python 3 conversion forum.
