Stumped to be sure in setting up
Mon Aug 28, 2023 11:56 am
BruceP offline
Over the past few hours I have been trying different email accounts to get an email sent. All I have received is error messages. I have separately logged into my email accounts to verify that all information is correct. Have gone online to get the appropriate ports and related information
I receive this error message when using my Cox Communications email - Email+ Error Email+ SMTP Server: SMTP server connection error: encoding with 'idna' codec failed (UnicodeError: label empty or too long)
When using my iCloud email - Email+ Error Email+ SMTP Server: SMTP server connection error: (535, b'5.7.8 Error: authentication failed')
Cox info is: SMTP host smtp.cox.net. Port 465, Encryption StartTLS
iCloud info is: SMTP host smtp.mail.me.com, Port 587, Encryption StartTLS
Any assistance will be welcome,
Thank you
Mon Aug 28, 2023 1:22 pm
Re: Stumped to be sure in setting up
First, have you set up IMAP or POP devices for these providers? Because if they work, using the same authentication credentials, that confirms that it's not really an auth issue.
For iCloud email, you cannot use your normal iCloud login for the plugin. You need to get an app-specific password. See https://support.apple.com/en-us/HT204397
I would try port 587 for Cox. 465 is deprecated and should not be used anymore (unless that's the only port the ISP supports).
Wed Aug 30, 2023 6:20 am
BruceP offline
Sorry for the late response. Due to other surprising goings-on I have not been able to get to this project. Will try again this weekend.
Again thank you.
