New Email+ Plugin with Indigo 2021.1 and later
Tue Jun 15, 2021 1:11 pm
With the release of Indigo 2021.1, we removed the old built-in email capabilities and replaced it with the Email+ Plugin which is based on the Better Email plugin from forum user @FlyingDiver (many thanks for his generous contribution). The 2021.1 installer will migrate both old settings and actions from the built-in email and any devices and actions from Better Email if it was installed.
If you are using a version prior to Indigo 2021.1, you should be using the Better Email plugin since it's significantly more reliable than the old built-in email. We will leave that plugin in the Plugin Store for users of older versions of Indigo.
Tue Jun 15, 2021 1:23 pm
Re: New Email+ Plugin with Indigo 2021.1 and later
Note that if you were directly scripting Better Email actions, you'll either need to leave Better Email installed, or your scripts will need to be changed to use the new Email+ plugin's identifier. Changing the scripts is the better solution.
Tue Jun 15, 2021 2:05 pm
Thank you for retaining the scripting capabilities. I use them often. :)
Tue Jun 15, 2021 2:07 pm
You can't actually continue to use the Better Email plugin after upgrading. But all the scripting and broadcast messages are still there, so you just need to change the ID in your scripts and subscriptions:
com.indigo.email
Tue Jun 15, 2021 2:09 pm
Agreed. I think we will eventually update the
indigo.server.sendEmailTo()
function to accept the same parameters that the direct scripting supports so it won't require getting the plugin instance first. It'll knock off a few lines of code... :)
Tue Jun 15, 2021 3:48 pm
norcoscia offline
I hope this works since I don’t understand the comments here -also hope somewhere along the way I did not do any scripting …
_______
Norm
Tue Jun 15, 2021 3:50 pm
norcoscia offline
Also did 2021 drop?
_______
Norm
Tue Jun 15, 2021 4:29 pm
Yeah, we really should have kept this discussion in the private beta forum until we actually release.
norcoscia wrote:
Also did 2021 drop?
Not yet, but we're super close. Watch the Announcements section or the Blog.
Tue Jun 15, 2021 4:30 pm
When 2021.1 ships it will contain functions of the Better Email plugin as standard. The Better Email plugin allows users to access some of its features with Python scripts (and through other plugins). We're simply discussing what features will be included.
Tue Jun 15, 2021 4:45 pm
norcoscia offline
Thanks Jay and Dave. , Excited to try out the new release ;-)
_______
Norm
Wed Jun 16, 2021 4:28 pm
eme jota ce offline
norcoscia wrote:
Also did 2021 drop?
Right! This thread had me searching the blog, clicking "Check for Updates" and trying to understand why I can't find the 2021.1 version. :?
Now I know ... not Beta-Cool in the eyes of Matt and Jay :cry: :wink:
Thu Jun 17, 2021 1:14 pm
Note that scripts or plugins that use the old Better Email plugin ID (for sending email or hooking into incoming email) should continue to work in Indigo 2021.1 with the Email+ plugin. That is, internally the Indigo Server will map the Better Email plugin ID to the new Email+ plugin ID automatically. Obviously updating the scripts or plugins to use the new ID is preferable but in theory nothing should break.
Thu Jun 17, 2021 3:59 pm
ryanbuckner offline
Thanks guys. And amazing work .
Thu Jun 17, 2021 8:07 pm
Indigo 2021.1 has been released. I'm locking this topic, please start new ones with your questions/comments.
