Alexa not discovering
Mon Aug 30, 2021 2:46 pm
siclark offline
Hi Jay
I had this working initially but then noticed that new devices were not discovering and existing ones stopped responding.
I've revoked access from indigo, disabled the app and then started again but it still doesn't work.
Any ideas how o can see what is going wrong?
Cheers
Mon Aug 30, 2021 3:08 pm
siclark offline
Re: Alexa not discovering
I've turned on detailed debugging and I can see records such as below when Alexa discovering is enabled,
   Alexa                           ...'Kitchen Table Spots' - Type: DimmerDevice - Subtype: Dimmer
   Alexa Debug                     IndigoDeviceEndpoint.__init__ called with device: 307688025 (Bedroom Pendant)
   Alexalib Debug                  CapabilityInterface.__init__ called...
   Alexalib Debug                    created the default Alexa interface
   Alexalib Debug                  EndpointHealth.__init__ called...
   Alexalib Debug                  BrightnessController.__init__ called...
   Alexalib Debug                  PowerController.__init__ called...
and then this below, but Alexa doesnt actually find the new devices (I have deleted all the Indigo devices out of Alexa to start again).
Any ideas about why this isnt working?
Simon.
  Alexa                           Found 14 devices to publish, replying
   Alexa Debug                     reply:
{"event": {"header": {"payloadVersion": "3", "namespace": "Alexa.Discovery", "name": "Discover.Response", "messageId": "XXXXXXXXXXX"}, "payload": {"endpoints": [{"additionalAttributes": {"model": "Double Switch 2 (FGS223)", "firmwareVersion": "3.03", "manufacturer": "Fibaro System"}, "endpointId": "1976227552", "capabilities": [{"interface": "Alexa", "version": "3", "type": "AlexaInterface"}, {"interface": "Alexa.EndpointHealth", "version": "3", "type": "AlexaInterface", "properties": {"retrievable": true, "supported": [{"name": "connectivity"}], "proactivelyReported": false}}, {"interface": "Alexa.PowerController", "version": "3", "type": "AlexaInterface", "properties": {"retrievable": true, "supported": [{"name": "powerState"}], "proactivelyReported": false}}], "connections": [{"homeId": "0x00000001", "type": "ZWAVE", "nodeId": "0x45"}], "manufacturerName": "Fibaro System", "friendlyName": "Flowerbed lights", "displayCategories": ["SWITCH"], "description": "Double Switch 2 (FGS223) by Fibaro System"}, {"additionalAttributes": {"model": "Outlet (Socket)", "manufacturer": "Generic Device"}, "endpointId": "747739968", "capabilities": [{"interface": "Alexa", "version": "3", "type": "AlexaInterface"}, {"interface": "Alexa.EndpointHealth", "version": "3", "type": "AlexaInterface", "properties": {"retrievable": true, "supported": [{"name": "connectivity"}], "proactivelyReported": false}}, {"interface": "Alexa.PowerController", "version": "3", "type": "AlexaInterface", "properties": {"retrievable": true, "supported": [{"name": "powerState"}], "proactivelyReported": false}}], "connections": [{"type": "UNKNOWN", "value": "immersion-heater"}], "manufacturerName": "Generic Device", "friendlyName": "Immersion Heater", "displayCategories": ["SMARTPLUG"], "description": "Generic Device via plugin 'Hubitat Bridge'"}, {"additionalAttributes": {"model": "Double Switch 2 (FGS223)", "firmwareVersion": "3.03", "manufacturer": "Fibaro System"}, "endpointId": "333904363", "capabilities": [{"interface": "Alexa", "version": "3", "type": "AlexaInterface"}, {"interface": "Alexa.EndpointHealth", "version": "3", "type": "AlexaInterface", "properties": {"retrievable": true, "supported": [{"name": "connectivity"}], "proactivelyReported": false}}, {"interface": "Alexa.PowerController", "version": "3", "type": "AlexaInterface", "properties": {"retrievable": true, "supported": [{"name": "powerState"}], "proactivelyReported": false}}], "connections": [{"homeId": "0x00000001", "type": "ZWAVE", "nodeId": "0x77"}], "manufacturerName": "Fibaro System", "friendlyName": "Patio spot lights", "displayCategories": ["SWITCH"], "description": "Double Switch 2 (FGS223) by Fibaro System"}, {"additionalAttributes": {"model": "Dimmer Switch (FGD212)", "softwareVersion": "4.24", "firmwareVersion": "3.05", "manufacturer": "Fibaro System"}, "endpointId": "83385445", "capabilities": [{"interface": "Alexa", "version": "3", "type": "AlexaInterface"}, {"interface": "Alexa.EndpointHealth", "version": "3", "type": "AlexaInterface", "properties": {"retrievable": true, "supported": [{"name": "connectivity"}], "proactivelyReported": false}}, {"interface": "Alexa.BrightnessController", "version": "3", "type": "AlexaInterface", "properties": {"retrievable": true, "supported": [{"name": "brightness"}], "proactivelyReported": false}}, {"interface": "Alexa.PowerController", "version": "3", "type": "AlexaInterface", "properties": {"retrievable": true, "supported": [{"name": "powerState"}], "proactivelyReported": false}}], "connections": [{"homeId": "0x00000001", "type": "ZWAVE", "nodeId": "0x5F"}], "manufacturerName": "Fibaro System", "friendlyName": "Kitchen Hob Spots", "displayCategories": ["LIGHT"], "description": "Dimmer Switch (FGD212) by Fibaro System"}, {"additionalAttributes": {"model": "Meta Relay", "manufacturer": "Generic Device"}, "endpointId": "1447844843", "capabilities": [{"interface": "Alexa", "version": "3", "type": "AlexaInterface"}, {"interface": "Alexa.EndpointHealth", "version": "3", "type": "AlexaInterface", "properties": {"retrievable": true, "supported": [{"name": "connectivity"}], "proactivelyReported": false}}, {"interface": "Alexa.PowerController", "version": "3", "type": "AlexaInterface", "properties": {"retrievable": true, "supported": [{"name": "powerState"}], "proactivelyReported": false}}], "connections": [{"type": "UNKNOWN", "value": ""}], "manufacturerName": "Generic Device", "friendlyName": "Part Arm House", "displayCategories": ["SWITCH"], "description": "Generic Device via plugin 'Meta Device'"}, {"additionalAttributes": {"model": "Double Switch 2 (FGS223)", "softwareVersion": "4.24", "firmwareVersion": "3.03", "manufacturer": "Fibaro System"}, "endpointId": "1634365746", "capabilities": [{"interface": "Alexa", "version": "3", "type": "AlexaInterface"}, {"interface": "Alexa.EndpointHealth", "version": "3", "type": "AlexaInterface", "properties": {"retrievable": true, "supported": [{"name": "connectivity"}], "proactivelyReported": false}}, {"interface": "Alexa.PowerController", "version": "3", "type": "AlexaInterface", "properties": {"retrievable": true, "supported": [{"name": "powerState"}], "proactivelyReported": false}}], "connections": [{"homeId": "0x00000001", "type": "ZWAVE", "nodeId": "0x45"}], "manufacturerName": "Fibaro System", "friendlyName": "Tree lights", "displayCategories": ["SWITCH"], "description": "Double Switch 2 (FGS223) by Fibaro System"}, {"additionalAttributes": {"model": "Flush 2 Micro Relay (ZMNHBD)", "softwareVersion": "4.5", "firmwareVersion": "1.01", "manufacturer": "Qubino"}, "endpointId": "914924080", "capabilities": [{"interface": "Alexa", "version": "3", "type": "AlexaInterface"}, {"interface": "Alexa.EndpointHealth", "version": "3", "type": "AlexaInterface", "properties": {"retrievable": true, "supported": [{"name": "connectivity"}], "proactivelyReported": false}}, {"interface": "Alexa.PowerController", "version": "3", "type": "AlexaInterface", "properties": {"retrievable": true, "supported": [{"name": "powerState"}], "proactivelyReported": false}}], "connections": [{"homeId": "0x00000001", "type": "ZWAVE", "nodeId": "0x62"}], "manufacturerName": "Qubino", "friendlyName": "Kitchen LED Strip", "displayCategories": ["SWITCH"], "description": "Flush 2 Micro Relay (ZMNHBD) by Qubino"}, {"additionalAttributes": {"model": "Dimmer Switch (FGD212)", "softwareVersion": "4.5", "firmwareVersion": "3.02", "manufacturer": "Fibaro System"}, "endpointId": "398612018", "capabilities": [{"interface": "Alexa", "version": "3", "type": "AlexaInterface"}, {"interface": "Alexa.EndpointHealth", "version": "3", "type": "AlexaInterface", "properties": {"retrievable": true, "supported": [{"name": "connectivity"}], "proactivelyReported": false}}, {"interface": "Alexa.BrightnessController", "version": "3", "type": "AlexaInterface", "properties": {"retrievable": true, "supported": [{"name": "brightness"}], "proactivelyReported": false}}, {"interface": "Alexa.PowerController", "version": "3", "type": "AlexaInterface", "properties": {"retrievable": true, "supported": [{"name": "powerState"}], "proactivelyReported": false}}], "connections": [{"homeId": "0x00000001", "type": "ZWAVE", "nodeId": "0x66"}], "manufacturerName": "Fibaro System", "friendlyName": "Lounge Pendant", "displayCategories": ["LIGHT"], "description": "Dimmer Switch (FGD212) by Fibaro System"}, {"additionalAttributes": {"model": "Dimmer Switch (FGD212)", "softwareVersion": "4.24", "firmwareVersion": "3.05", "manufacturer": "Fibaro System"}, "endpointId": "433963128", "capabilities": [{"interface": "Alexa", "version": "3", "type": "AlexaInterface"}, {"interface": "Alexa.EndpointHealth", "version": "3", "type": "AlexaInterface", "properties": {"retrievable": true, "supported": [{"name": "connectivity"}], "proactivelyReported": false}}, {"interface": "Alexa.BrightnessController", "version": "3", "type": "AlexaInterface", "properties": {"retrievable": true, "supported": [{"name": "brightness"}], "proactivelyReported": false}}, {"interface": "Alexa.PowerController", "version": "3", "type": "AlexaInterface", "properties": {"retrievable": true, "supported": [{"name": "powerState"}], "proactivelyReported": false}}], "connections": [{"homeId": "0x00000001", "type": "ZWAVE", "nodeId": "0x5E"}], "manufacturerName": "Fibaro System", "friendlyName": "Kitchen Table Spots", "displayCategories": ["LIGHT"], "description": "Dimmer Switch (FGD212) by Fibaro System"}, {"additionalAttributes": {"model": "Flush Micro Dimmer (ZMNHDD)", "softwareVersion": "4.5", "firmwareVersion": "3.05", "manufacturer": "Qubino"}, "endpointId": "307688025", "capabilities": [{"interface": "Alexa", "version": "3", "type": "AlexaInterface"}, {"interface": "Alexa.EndpointHealth", "version": "3", "type": "AlexaInterface", "properties": {"retrievable": true, "supported": [{"name": "connectivity"}], "proactivelyReported": false}}, {"interface": "Alexa.BrightnessController", "version": "3", "type": "AlexaInterface", "properties": {"retrievable": true, "supported": [{"name": "brightness"}], "proactivelyReported": false}}, {"interface": "Alexa.PowerController", "version": "3", "type": "AlexaInterface", "properties": {"retrievable": true, "supported": [{"name": "powerState"}], "proactivelyReported": false}}], "connections": [{"homeId": "0x00000001", "type": "ZWAVE", "nodeId": "0x5A"}], "manufacturerName": "Qubino", "friendlyName": "Bedroom Pendant", "displayCategories": ["LIGHT"], "description": "Flush Micro Dimmer (ZMNHDD) by Qubino"}, {"additionalAttributes": {"model": "Double Switch 2 (FGS223)", "softwareVersion": "4.5", "firmwareVersion": "3.02", "manufacturer": "Fibaro System"}, "endpointId": "1995973658", "capabilities": [{"interface": "Alexa", "version": "3", "type": "AlexaInterface"}, {"interface": "Alexa.EndpointHealth", "version": "3", "type": "AlexaInterface", "properties": {"retrievable": true, "supported": [{"name": "connectivity"}], "proactivelyReported": false}}, {"interface": "Alexa.PowerController", "version": "3", "type": "AlexaInterface", "properties": {"retrievable": true, "supported": [{"name": "powerState"}], "proactivelyReported": false}}], "connections": [{"homeId": "0x00000001", "type": "ZWAVE", "nodeId": "0x68"}], "manufacturerName": "Fibaro System", "friendlyName": "Fountain", "displayCategories": ["SWITCH"], "description": "Double Switch 2 (FGS223) by Fibaro System"}, {"additionalAttributes": {"model": "Dimmer Switch (FGD212)", "softwareVersion": "4.24", "firmwareVersion": "3.05", "manufacturer": "Fibaro System"}, "endpointId": "558991579", "capabilities": [{"interface": "Alexa", "version": "3", "type": "AlexaInterface"}, {"interface": "Alexa.EndpointHealth", "version": "3", "type": "AlexaInterface", "properties": {"retrievable": true, "supported": [{"name": "connectivity"}], "proactivelyReported": false}}, {"interface": "Alexa.BrightnessController", "version": "3", "type": "AlexaInterface", "properties": {"retrievable": true, "supported": [{"name": "brightness"}], "proactivelyReported": false}}, {"interface": "Alexa.PowerController", "version": "3", "type": "AlexaInterface", "properties": {"retrievable": true, "supported": [{"name": "powerState"}], "proactivelyReported": false}}], "connections": [{"homeId": "0x00000001", "type": "ZWAVE", "nodeId": "0x69"}], "manufacturerName": "Fibaro System", "friendlyName": "Garden step lights", "displayCategories": ["LIGHT"], "description": "Dimmer Switch (FGD212) by Fibaro System"}, {"additionalAttributes": {"model": "Meta Relay", "manufacturer": "Generic Device"}, "endpointId": "1415249884", "capabilities": [{"interface": "Alexa", "version": "3", "type": "AlexaInterface"}, {"interface": "Alexa.EndpointHealth", "version": "3", "type": "AlexaInterface", "properties": {"retrievable": true, "supported": [{"name": "connectivity"}], "proactivelyReported": false}}, {"interface": "Alexa.PowerController", "version": "3", "type": "AlexaInterface", "properties": {"retrievable": true, "supported": [{"name": "powerState"}], "proactivelyReported": false}}], "connections": [{"type": "UNKNOWN", "value": ""}], "manufacturerName": "Generic Device", "friendlyName": "Part Arm Drive", "displayCategories": ["SWITCH"], "description": "Generic Device via plugin 'Meta Device'"}, {"additionalAttributes": {"model": "Double Switch 2 (FGS223)", "softwareVersion": "4.24", "firmwareVersion": "3.03", "manufacturer": "Fibaro System"}, "endpointId": "1445308831", "capabilities": [{"interface": "Alexa", "version": "3", "type": "AlexaInterface"}, {"interface": "Alexa.EndpointHealth", "version": "3", "type": "AlexaInterface", "properties": {"retrievable": true, "supported": [{"name": "connectivity"}], "proactivelyReported": false}}, {"interface": "Alexa.PowerController", "version": "3", "type": "AlexaInterface", "properties": {"retrievable": true, "supported": [{"name": "powerState"}], "proactivelyReported": false}}], "connections": [{"homeId": "0x00000001", "type": "ZWAVE", "nodeId": "0x77"}], "manufacturerName": "Fibaro System", "friendlyName": "Patio wall lights", "displayCategories": ["SWITCH"], "description": "Double Switch 2 (FGS223) by Fibaro System"}]}}}
Mon Aug 30, 2021 3:45 pm
Check out the troubleshooting section of the docs and try all those suggestions.
Mon Aug 30, 2021 4:10 pm
siclark offline
Cheers. Right at the end was this key bit of info.
 The v2021.1.0 version of the skill has an issue when a device contains an empty string “” as the device's address. If you look at the device's Address column in the device list and see nothing, that's an indication that it likely will cause a discovery failure (of all devices, not just the one with the bad address).
Mon Aug 30, 2021 4:41 pm
That’s fixed in v2021.1.1…
It’s always best to keep up with the latest bug fix release.
Tue Aug 31, 2021 2:24 am
siclark offline
haha.. cheers. That would indeed be the bst thing if I had had time to keep up with the annoucements, let alone install it. However yes, confirm it now works with the .1 release.
Really need more hours in the day...
