Alexa transition
Fri Aug 13, 2021 5:04 am
Re: Alexa transition
No, there is no reason at all.
You can let the Alexa-Hue Bridge Plugin enjoys its well earned retirement. :D
Fri Aug 13, 2021 11:09 pm
sarahcat offline
Thank you, Jon!
Rest well, Alexa-Hue Bridge. As Jon said, you've earned it.
Sun Mar 26, 2023 5:06 pm
cjp767 offline
I also had a problem with Hue devices not deleting in the Alexa app. They were causing a problem because I was getting the Alexa error message "There are a few devices with the name xxx lights, which do you want?" Alexa had zombie Hue plugin devices and new Alexa plugin devices with the same name, so Alexa would occasionally get confused.
Here's what I did to finally make them go away:
1. Disabled the Indigo Alexa plugin by revoking privileges on my Indigo account and disabled the Indigo Alexa plugin
2. Deleted all of my Alexa devices on https://alexa.amazon.com
3. Turned on the old Alexa Hue bridge plugin and created one Hue device with zero lights
4. Performed "Discover Devices" on Alexa--- It found no devices, thankfully
5. Disabled the old Alexa Hue bridge plugin in Indigo
6. Reenabled my Indigo Alexa plugin by authorizing it on my Indigo account and enabled Indigo's Alexa plugin
7. Performed "Discover Devices" on Alexa. It found all my Alexa Indigo plugin published devices and thankfully no Hue devices
8. Went through the Alexa app to set up each device.
I'm not sure if all of these steps are necessary-- but it seems to have worked. This whole experience was rather tedious and frustrating. But the zombie Hue devices are gone and Alexa seems to be linked and working properly. For now.
