Alexa retrieves variable value but fails - SOLVED
Thu Sep 30, 2021 6:12 pm
ryanbuckner offline
Every few time I try to ask Alexa for the value of a variable , I get "I'm having trouble accessing your Indigo Server Skill Skill right now" . But it appears to retrieve the value. Here's. what's in the debug:
Sep 30, 2021 at 8:05:45 PM
Alexa Debug variable_actions API call received
Alexa request the value of variable 'forestville_lunch_tomorrow'
Alexa Debug reply:
{"speak_string": "Cheese Pizza or Pepperoni Pizza or PB&J Biteable or Yogurt Biteable", "status": "success", "variable_name": "forestville lunch tomorrow", "variable_name_mangled": "forestville_lunch_tomorrow"}
Rather than speaking the value, it said "I'm having trouble accessing your Indigo Server Skill Skill right now"
Fri Oct 01, 2021 8:52 am
Re: Alexa retrieves variable value but fails
Unfortunately, that error is generated by Alexa. Since we're returning the appropriate response (as per the debug reply above) I have no insight into why Alexa is returning an error. If you immediately say exactly the same thing again, does it work? If so, and you get two identical debug replies like above, then there really isn't anything we can do about it since it's totally on the Alexa side.
Fri Oct 01, 2021 9:06 am
I was able to find the Amazon logs for processing the event specified above. It shows that everything went correctly from our skill's side:
[DEBUG]   2021-10-01T00:05:45.145Z   XXXXXXXXXXXXXXXX   GetVariableValueIntent.handle() called...
[DEBUG]   2021-10-01T00:05:45.145Z   XXXXXXXXXXXXXXXX   locale: en-US
[DEBUG]   2021-10-01T00:05:45.145Z   XXXXXXXXXXXXXXXX   variable name: forestville lunch tomorrow
[DEBUG]   2021-10-01T00:05:45.145Z   XXXXXXXXXXXXXXXX   payload:
[DEBUG]   2021-10-01T00:05:45.145Z   XXXXXXXXXXXXXXXX   {
"locale": "en-US",
"action": "get_variable_value"
[DEBUG]   2021-10-01T00:05:45.864Z   XXXXXXXXXXXXXXXX   reply:
[DEBUG]   2021-10-01T00:05:45.864Z   XXXXXXXXXXXXXXXX   {
"variable_name_mangled": "forestville_lunch_tomorrow",
END RequestId: XXXXXXXXXXXXXXXX
This shows the entire event flow from our skill's perspective: we get the request for a variable value with the given name, we format that into the request that gets passed to the Alexa plugin, the plugin replies (as seen in your debug log), our skill (hosted on Amazon's servers) receives the reply and returns the value of "speak_string" to Amazon. Nowhere do we show any errors, so I don't know why you wouldn't have gotten the appropriate response. I wish I had found some errors that we could address...
Fri Oct 01, 2021 10:44 am
ryanbuckner offline
I'd say it works 75% of the time when trying the same thing right away
Fri Oct 01, 2021 2:04 pm
And you always see the reply debug in the log? If you do, then the problem will almost certainly be on Amazon's side. If, however, you say something and you get an error but no debug logging, then the problem could be that your reflector connection is having an issue. I would expect there to be errors in the Event Log however that would indicate that there were some kind of issue with the reflector or any part of the flow on the Indigo side.
Mon Oct 04, 2021 7:10 am
ryanbuckner offline
I've tried renaming variables and action groups. I think I'm giving up on the Alexa feature for a while.
Wed Oct 13, 2021 6:30 am
ryanbuckner offline
Tried again today ... same result: "Having trouble accessing your Indigo skill skill"
Oct 13, 2021 at 8:27:54 AM
   Alexa                           Turning on debug logging
   Alexa                           request the value of variable 'lunch_today'
   Alexa Debug                     reply:
{"speak_string": "Baked Chicken on Bun or PB&J Biteable or Yogurt Biteable", "status": "success", "variable_name": "lunch today", "variable_name_mangled": "lunch_today"}
Wed Oct 13, 2021 1:14 pm
It doesn't like the & in the string value. Change it to "and" and it will work.
Thu Oct 14, 2021 6:36 am
ryanbuckner offline
The '&' is pulled from the API for Nutrislice. I can try to change it in the script.
That night be why Alexa has no problem pulling the breakfast_today variable but fails on the lunch_today variable. Damn PB&J Bites.
Oct 14, 2021 at 8:32:26 AM
   Alexa                           request the value of variable 'breakfast_today'
   Alexa Debug                     reply:
{"speak_string": "Apple Cinnamon Muffin Top or Cheerios", "status": "success", "variable_name": "breakfast today", "variable_name_mangled": "breakfast_today"}
Oct 14, 2021 at 8:32:58 AM
   Schedule                        1st Floor Bathroom on Motion - OFF (delayed action)
   Sent INSTEON                    "1st Floor Bathroom Light" off
   Alexa Debug                     deviceUpdated: 1st Floor Bathroom Light
   Alexa Debug                     original device type: RelayDevice, updated device type: RelayDevice
   Alexa Debug                     IndigoDeviceEndpoint.__init__ called with device: 1507246897 (1st Floor Bathroom Light)
   Alexa Debug                     reply:
{"speak_string": "Macaroni & Cheese or PB&J Biteable or Yogurt Biteable", "status": "success", "variable_name": "lunch today", "variable_name_mangled": "lunch_today"}
Thu Oct 14, 2021 6:42 am
ryanbuckner offline
It worked!!
foodlist.append(item['food']['name'].replace("&", " and "))
returned:
Oct 14, 2021 at 8:41:25 AM
   Alexa Debug                     reply:
{"speak_string": "Macaroni  and  Cheese or PB and J Biteable or Yogurt Biteable", "status": "success", "variable_name": "lunch today", "variable_name_mangled": "lunch_today"}
Thu Oct 14, 2021 11:12 am
Re: Alexa retrieves variable value but fails - SOLVED
I think you could also use the html module:
import html
foodlist.append(html.escape(item['food']['name']))
That would generate "Macaroni and Cheese or PB&J Biteable or Yogurt Biteable" which appears to work as well. It might also catch other things that might cause hiccups.
Thu Oct 14, 2021 3:36 pm
ryanbuckner offline
It generated Macaroni & Cheese or PB&J Biteable or Yogurt Biteable
Appears to work well. I'll go with this.
