Variable issue
Sun Jun 27, 2021 9:12 am
ryanbuckner offline
Variable issue
I'm getting mixed results when asking for variables.
Sometimes it works and other times I get "Sorry, I'm having trouble accessing your Indigo Skills skill right now "
Sun Jun 27, 2021 9:27 am
Re: Variable issue
[MODERATOR NOTE]: Split to a new topic since it's a different issue.
A couple of questions:
1) Is that the exact wording of the message?
2) Is this when you ask for a variable value or for a list of variables (or both)?
3) Does the error only happen after 6+ minutes of inactivity? In other words, does this only happen after you haven't asked Alexa to do anything from Indigo (control device, run action, get variable) for over 6 minutes, then once you get the error if you try again immediately it works?
Sun Jun 27, 2021 9:44 am
ryanbuckner offline
Re: Variable issue
1) The exact wording of the message is "Sorry, I'm having trouble accessing your Indigo Skills skill right now ".
2) Variable value. I asked, "Alexa, ask Indigo to read if garage doors are open". The variable name is "if_garage_doors_are_open" based on the example in the docs "Alexa, ask Indigo to read “current_weather_conditions”"
3) I successfully had Alexa turn on the Island Lights and then made the request above immediately after.
Sun Jun 27, 2021 10:23 am
Re: Variable issue
I do wonder if having the "if" in the name is causing Alexa to try to apply that to the skill rather than as part of the name.
Try renaming the variable.
Sun Jun 27, 2021 7:36 pm
ryanbuckner offline
Re: Variable issue
I renamed the variable "garage_door_status" and got the same result. To test the 6 min theory I used the skill to turn on and off a few lights, then tried again. Same result:
Mon Jun 28, 2021 8:58 am
Re: Variable issue
Turn on debugging in the Alexa menu, then perform the command again. Copy/paste anything that shows up as a result.
Mon Jun 28, 2021 9:57 am
ryanbuckner offline
Re: Variable issue
Same reply from Alexa. Here's the debug:
Jun 28, 2021 at 11:55:18 AM
   Alexa Debug                     variable_actions API call received
   Alexa                           request the value of variable 'garage_door_status'
   Alexa Debug                     reply:
{"speak_string": "<Both garage doors are closed", "status": "success", "variable_name": "garage door status", "variable_name_mangled": "garage_door_status"}
Looks like we found the issue. The "<" somehow got in there and confused Alexa
Mon Jun 28, 2021 10:15 am
Re: Variable issue
Strings that go back to Alexa may contain SSML - a markup language similar to HTML. When it found an unbalanced < it literally threw the baby out with the bath water. This is their approach to everything: the slightest thing that they don't expect causes a general failure rather than using some intelligence.
I'll make a note of it in the Troubleshooting section of the docs.
