error changing settings.
Tue Jun 21, 2022 11:02 pm
agame offline
Hi, I've been using some scripts to control a Daikin but thought i would give the plugin a go, in order to publish a device to HomeKit.
The plugin can correctly read all settings and ambient temperature, however any attempt to alter settings generates an error:
actionValue : 0.0
configured : True
delayAmount : 900
description : set mode of thermostat to all off
deviceId : 26784696
replaceExisting : True
textToSpeak :
thermostatAction : SetHvacMode
   Daikin Wifi Controller          0
   Daikin Wifi Controller          off
   Daikin Wifi Controller Debug    action string is off
   Daikin Wifi Controller Debug    http://192.168.1.111/aircon/set_control_info?pow=0&mode=4&stemp=24.0&shum=0&f_rate=5&f_dir=3
   Daikin Wifi Controller Error    Unknown/Other Error setting /aircon/set_control_info?pow=0&mode=4&stemp=24.0&shum=0&f_rate=5&f_dir=3 from Daikin Unit daikin - new plugin
   Daikin Wifi Controller Debug    Error is HTTPConnectionPool(host='192.168.1.111', port=80): Read timed out. (read timeout=2)
   Daikin Wifi Controller Error    send "daikin - new plugin" mode change to off failed
   Daikin Wifi Controller Debug    [['ret', 'OK'], ['pow', '1'], ['mode', '4'], ['adv', ''], ['stemp', '24.0'], ['shum', '0'], ['dt1', '25.0'], ['dt2', 'M'], ['dt3', '27.0'], ['dt4', '24.0'], ['dt5', '24.0'], ['dt7', '25.0'], ['dh1', 'AUTO'], ['dh2', '0'], ['dh3', '0'], ['dh4', '0'], ['dh5', '0'], ['dh7', 'AUTO'], ['dhh', '50'], ['b_mode', '4'], ['b_stemp', '24.0'], ['b_shum', '0'], ['alert', '255'], ['f_rate', '5'], ['f_dir', '3'], ['b_f_rate', '5'], ['b_f_dir', '3'], ['dfr1', '5'], ['dfr2', '5'], ['dfr3', '5'], ['dfr4', '5'], ['dfr5', '5'], ['dfr6', '5'], ['dfr7', '5'], ['dfrh', '5'], ['dfd1', '0'], ['dfd2', '3'], ['dfd3', '3'], ['dfd4', '3'], ['dfd5', '3'], ['dfd6', '0'], ['dfd7', '0'], ['dfdh', '0'], ['ret', 'OK'], ['htemp', '24.0'], ['hhum', '-'], ['otemp', '11.0'], ['err', '0'], ['cmpfreq', '58']]
   Daikin Wifi Controller Debug    [['ret', 'OK'], ['pow', '1'], ['mode', '4'], ['adv', ''], ['stemp', '24.0'], ['shum', '0'], ['dt1', '25.0'], ['dt2', 'M'], ['dt3', '27.0'], ['dt4', '24.0'], ['dt5', '24.0'], ['dt7', '25.0'], ['dh1', 'AUTO'], ['dh2', '0'], ['dh3', '0'], ['dh4', '0'], ['dh5', '0'], ['dh7', 'AUTO'], ['dhh', '50'], ['b_mode', '4'], ['b_stemp', '24.0'], ['b_shum', '0'], ['alert', '255'], ['f_rate', '5'], ['f_dir', '3'], ['b_f_rate', '5'], ['b_f_dir', '3'], ['dfr1', '5'], ['dfr2', '5'], ['dfr3', '5'], ['dfr4', '5'], ['dfr5', '5'], ['dfr6', '5'], ['dfr7', '5'], ['dfrh', '5'], ['dfd1', '0'], ['dfd2', '3'], ['dfd3', '3'], ['dfd4', '3'], ['dfd5', '3'], ['dfd6', '0'], ['dfd7', '0'], ['dfdh', '0'], ['ret', 'OK'], ['htemp', '24.0'], ['hhum', '-'], ['otemp', '11.0'], ['err', '0'], ['cmpfreq', '58'], ['ret', 'OK'], ['curr_day_heat', '0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0'], ['prev_1day_heat', '0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0'], ['curr_day_cool', '0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0'], ['prev_1day_cool', '0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0/0'], ['ret', 'OK'], ['s_dayw', '3'], ['week_heat', '0/0/0/0/0/0/0/0/0/0/0/0/0/0'], ['week_cool', '0/0/0/0/0/0/0/0/0/0/0/0/0/0'], ['ret', 'OK'], ['curr_year_heat', '0/0/0/0/0/0/0/0/0/0/0/0'], ['prev_year_heat', '0/0/0/0/0/0/0/0/0/0/0/0'], ['curr_year_cool', '0/0/0/0/0/0/0/0/0/0/0/0'], ['prev_year_
The URL the plugin is generating looks identical to what my script uses....and as you can see there is an error reported: any idea what is happening?
Wed Jun 22, 2022 2:18 am
neilk offline
Re: error changing settings.
So if you post into a browser (or curl it from a script)
Everything works OK.
The read timeout error is strange as the controller IP must be correct as it is returning data from the updates.
Do you have any other network related issues or latency problems, on my unit it intermittently fails to respond to to a status request but only for one cycle and it self corrects. Do you ever see any errors in the log relating to that ?
If it really is a timeout issue then I can look to make quick and dirty change for you to test, and then make it configurable but this is really not much else to tweak.
If you want to share your scripts as well I can take a look and see if something is subtly different.
Neil
Wed Jun 22, 2022 3:06 am
agame offline
actually the url returns the the response
ret=OK,adv=
and doesn't do anything.
here's the script I use to set commands. Much of it is about managing UI elements however you will see the URL generation.
import requests
pow = indigo.variables[469667786].value # "upstairs_aircon_pow_target"
mode = indigo.variables[1560422268].value # "upstairs_aircon_mode_target"
stemp = indigo.variables[432309815].value # "upstairs_aircon_stemp_target"
f_rate = indigo.variables[1963800654].value # "upstairs_aircon_fanspeed_target"
f_dir = indigo.variables[1974389442].value # "upstairs_aircon_fandir_target"
##pow_actual = indigo.variables[1199721418].value # "upstairs_aircon_pow_actual"
indigo.server.log("mode is " + mode)
##if pow_actual.value == False:
url = "http://192.168.1.111/aircon/set_control_info?pow=" + pow +"&mode=" + mode + "&stemp=" + stemp + "&shum=0" + "&f_rate=" + f_rate + "&f_dir=" + f_dir
requests.get(url)
indigo.server.log("updated upstairs daikin settings")
coolmodeIcon = indigo.variables[1194462574]. value # "upstairs_aircon_coolmode_state"
drymodeIcon = indigo.variables[1294622760]. value # "upstairs_aircon_drymode_state"
fanmodeIcon = indigo.variables[647775410]. value # "upstairs_aircon_fanmode_state"
heatmodeIcon = indigo.variables[586965895].value # "upstairs_aircon_heatmode_state"
if   mode  == '3':   #cool
   indigo.variable.updateValue(757312318, value='cool') #modetargettext
   indigo.variable.updateValue(1194462574, value='True') #cool icon
   indigo.variable.updateValue(1294622760, value='False') #dry icon
   indigo.variable.updateValue(647775410, value='False') #fan icon
   indigo.variable.updateValue(586965895, value='False') #heat icon
elif mode  == '4': #heat
   indigo.variable.updateValue(757312318, value='heat') #modetargettext
   indigo.variable.updateValue(1194462574, value='False') #cool icon
   indigo.variable.updateValue(586965895, value='True') #heat icon
elif mode  == '2': #dry
   indigo.variable.updateValue(757312318, value='dry') #modetargettext
   indigo.variable.updateValue(1294622760, value='True') #dry icon
elif mode  == '6':  #fan
   indigo.variable.updateValue(757312318, value='fan') #modetargettext
   indigo.variable.updateValue(647775410, value='True') #fan icon
else :
   indigo.server.log( "error setting hvac mode icons")
Wed Jun 22, 2022 3:27 am
agame offline
i've found what breaks it:. the plugin is passing the temp value with a decimal place. when i round to an integer, it works.
url generated by plugin
url generated by my script
http://192.168.1.111/aircon/set_control_info?pow=0&mode=4&stemp=24&shum=0&f_rate=5&f_dir=3
Wed Jun 22, 2022 3:50 pm
neilk offline
Thanks for the sleuthing. Which controller are you using ?
It looks like something for a specific device type, I am away for a few days but will test and look to a configurable fix for this if it is device specific
I checked the. API documentation and the call I use appear to be valid, but I will double check in testing.
Wed Jun 22, 2022 4:52 pm
agame offline
i think the Daikin APIs are reverse engineered, and vary slightly by region,so the doco may not be reliable.
[Does anyone actually need a fraction-of-degree precision?!]
The interface i'm using is the Daikin BRP072A42.
Wed Jun 22, 2022 11:25 pm
neilk offline
Indeed it varies both by region and model and is not very consistent on identical features.
I will sort one way or another now we know but it may be next week.
Neil
Wed Jun 22, 2022 11:35 pm
agame offline
no stress, thx!
Sun Jul 03, 2022 5:13 am
neilk offline
I created a test release https://github.com/neilkplugins/Daikin-Wifi-indigo-plugin/releases/tag/2022.0.7alpha
That should address the issue. A new device configuration check box is added that says "Does the unit support decimal points", this is on by default but if you uncheck this all api calls should now be integers only.
It is possible I missed something as multiple different methods to change (as pretty much all actions include the setpoint parameter) but I think I caught them all.
Please do let me know if this works, or I have missed anything. I don't use the HomeKit plugin yet, so if I need to furthe optimise then I will as I also plan to.
If it works for you I will add to the plugin store (with the other fix in this release to make consumption API calls configurable)
Neil
Mon Jul 04, 2022 4:07 am
neilk offline
After you upgrade you will need to open and edit the device properties otherwise you will get an error., once you save the configuration changes it should go away
I will fix for the release version.
Neil
Mon Jul 04, 2022 6:38 am
neilk offline
https://github.com/neilkplugins/Daikin-Wifi-indigo-plugin/releases/tag/2022.0.8alpha fixes the issue if you are upgrading from an earlier version and to remove the need to edit/save the device properties
Neil
