Announcing Pre-Release Daikin Wifi Controller Plugin
Posted: Sat May 29, 2021 6:52 am
Hi all,
I have this working with my newly installed unit. You can find the details https://github.com/neilkplugins/Daikin-Wifi-indigo-plugin it is pretty self explanatory as it largely adopts the standard thermostat device and actions. This is an alpha version and will have issues but they should be minor, please feed back. I need to refine some of the image state settings but otherwise it should be fully functional. I will also look to add support for power consumption and special operations. If you have one of the wifi controllers that requires https then the basis for support for this is in the plugin, but I cannot test it. Also I cannot switch my unit to Fahrenheit to test the switching but it should be fine, again let me know of any issues.
First release is https://github.com/neilkplugins/Daikin-Wifi-indigo-plugin/releases/tag/0.0.2-Alpha
Please do let me know how you get on.
Neil
Neil
