SmartSetpoints plugin automates learning of your preferred temperatures throughout the day. Rather than just have fixed Heat/Cool setpoints, this plugin captures setpoint values as you manipulate the thermostat settings. Essentially, the last 10 setpoint values for each hour of the day are collected. On regular intervals, the plugin will update the Thermostat Setpoints to an average for the collected values for the current hour of day.
Plugin Features
* Device Types - supports devices that extend the Indigo Thermostat device type
* Smart Setpoint Tracking - Learns the preferred setpoints based on time of day, collecting values as you interact with the thermostat. Currently stores the last 10 changes made for heat/cool setpoints for each hour of the day.
* Setpoint Automation - Automatically updates the configured thermostat with an average of these last 10 values for the current hour of the day.
* Setpoint Automation Interval - the plugin attempts to update the thermostat setpoints periodically, based on a plugin configuration interval. However, if the setpoint was recently updated manually, the setpoints will be left as-is.
Supported Indigo Device Types
The plugin works with the Indigo Thermostat device. So far, it's been tested with the Insteon Thermostat as well as the virtual thermostat plugin 'Unistat'
For Installation, Setup, Usage refer to the GitHub wiki: https://github.com/rbdubz3/smart-setpoints-indigo/wiki
V1.1.2 Changes
* Fixed bug with handling of Change Capture Interval plugin preference
V1.1.1 Changes
* Added plugin configuration settings - Setpoint Automation Interval, Manual Pause Interval, and Change Capture Interval
