Was working but lately get "device_not_found"
Fri Jul 16, 2021 7:13 pm
srkinard offline
Hey Karl...
For a bit the plugin was working for me fine, but I recently noticed it has my ATV in Red with device_not_found as the status.
Almost everything I have uses static IPs and the ATV is most definitely online at that IP...shows up in my HomeKit apps, etc.
   appleTV
=================== parameter, devices used, set ..===========================
Parameters -----------
path To python3            : /usr/bin/python3
check for new devices every: 60 minutes
ignored IP numbers: {}
Devices --------------
appletv_192.168.100.81; id:1190800478; enabled:True; ignored:False
    AIRPLAYPort                   : 7000
    DMAPPort                      :
    MAC                           : C8:69:CD:3A:09:20
    MRPPort                       : 49152
    PowerState                    :
    currentlyPlaying_Album        :
    currentlyPlaying_App          :
    currentlyPlaying_AppId        :
    currentlyPlaying_Artist       :
    currentlyPlaying_DeviceState  :
    currentlyPlaying_Genre        :
    currentlyPlaying_MediaType    :
    currentlyPlaying_Position     :
    currentlyPlaying_Repeat       :
    currentlyPlaying_Shuffle      :
    currentlyPlaying_Title        :
    currentlyPlaying_TotalTime    :
    deepSleep                     : False
    identifier                    : 182716A3-6FD7-45A0-9D00-8DDDC2346D89
    ip                            : 192.168.100.81
    model                         : 4 tvOS 15.0
    pin                           :
    status                        : failure
    status.ui                     : device_not_found
Any ideas?
Ross
Fri Jul 16, 2021 7:14 pm
srkinard offline
Re: Was working but lately get "device_not_found"
I guess I should note that it's running tvOS 15 beta also...
Sat Jul 17, 2021 9:59 am
The name has to be 8 or less characters.
I am out of town for 4 weeks little chance to really test anything
Karl.
And now 2 days w/o luggage , still in Houston. And the Apple Tags really work. I know exactly where my luggage is- in the middle of terminal c- The airline does not know it and can not use that info.
Sat Jul 17, 2021 10:36 am
srkinard offline
Thanks Karl...sorry about the travel issues...hopefully they'll get your luggage to you soon.
Which airline?
I changed the name of the unit to "Bed ATV" so it's 7 characters now...it didn't refresh in the device list even after restarting the plugin.
I deleted the device in Indigo and re-scanned for new devices but nothing.
I'm tailing the log while it runs but not seeing errors...you can see where I hit reload on the plugin, etc.
indigo ->$ tail -f /Library/Application\ Support/Perceptive\ Automation/Indigo\ 2021.1/Logs/com.karlwachs.appleTV/plugin.log
17 11:16:42 in loop #19
17 11:16:53 in loop #20
17 11:17:03 in loop #21
17 11:17:14 in loop #22
17 11:17:25 in loop #23
17 11:17:35 in loop #24
17 11:17:45 in loop #25
17 11:17:56 in loop #26
17 11:18:07 in loop #27
17 11:18:17 in loop #28
17 11:18:27 in loop #29
17 11:18:38 in loop #30
17 11:18:48 in loop #31
17 11:18:59 in loop #32
17 11:19:09 in loop #33
17 11:19:20 in loop #34
17 11:19:20 =========getscriptScan cmd:[u'/usr/bin/python3', '/Library/Application Support/Perceptive Automation/Indigo 2021.1/Plugins/appleTV.indigoPlugin/Contents/Server Plugin/scripts/atvscript.py', 'scan']
17 11:19:26 =========getscriptScan out:('{"result": "success", "datetime": "2021-07-17T11:19:26.464063-05:00", "devices": []}\n', '')
17 11:19:26 =========getscriptScan out:{"result": "success", "datetime": "2021-07-17T11:19:26.464063-05:00", "devices": []}
17 11:19:26 =========getscriptScan dict:{}
17 11:19:26 =========getNewDevices scan result:{}
17 11:19:37 in loop #35
17 11:19:47 in loop #36
17 11:19:57 in loop #37
17 11:20:08 in loop #38
17 11:20:18 in loop #39
17 11:20:29 in loop #40
17 11:20:39 in loop #41
17 11:20:50 in loop #42
17 11:21:00 in loop #43
17 11:21:11 in loop #44
17 11:21:26 logger  enabled for     THREADDEBUG    ==> TEST ONLY
17 11:21:26 logger  enabled for     DEBUG          ==> TEST ONLY
17 11:21:26 logger  enabled for     INFO           ==> TEST ONLY
17 11:21:26 logger  enabled for     WARNING        ==> TEST ONLY
2021-07-17 11:21:26.553   ERROR          Plugin.__init__                  logger  enabled for     ERROR          ==> TEST ONLY
2021-07-17 11:21:26.553   CRITICAL       Plugin.__init__                  logger  enabled for     CRITICAL       ==> TEST ONLY
17 11:21:26 START:  path To python3                /usr/bin/python3
17 11:21:26 START:  check for new devices every    60 minutes
17 11:21:26 START:  runConcurrentThread, initialized loop settings
17 11:21:26 in loop #1
17 11:21:26 =========getscriptScan cmd:[u'/usr/bin/python3', '/Library/Application Support/Perceptive Automation/Indigo 2021.1/Plugins/appleTV.indigoPlugin/Contents/Server Plugin/scripts/atvscript.py', 'scan']
17 11:21:32 =========getscriptScan out:('{"result": "success", "datetime": "2021-07-17T11:21:32.887606-05:00", "devices": []}\n', '')
17 11:21:32 =========getscriptScan out:{"result": "success", "datetime": "2021-07-17T11:21:32.887606-05:00", "devices": []}
17 11:21:32 =========getscriptScan dict:{}
17 11:21:32 =========getNewDevices scan result:{}
17 11:21:43 in loop #2
17 11:21:53 in loop #3
17 11:22:04 in loop #4
17 11:22:14 in loop #5
17 11:22:25 in loop #6
17 11:22:35 in loop #7
17 11:22:35 =========getscriptScan cmd:[u'/usr/bin/python3', '/Library/Application Support/Perceptive Automation/Indigo 2021.1/Plugins/appleTV.indigoPlugin/Contents/Server Plugin/scripts/atvscript.py', 'scan']
17 11:22:42 =========getscriptScan out:('{"result": "success", "datetime": "2021-07-17T11:22:41.962694-05:00", "devices": []}\n', '')
17 11:22:42 =========getscriptScan out:{"result": "success", "datetime": "2021-07-17T11:22:41.962694-05:00", "devices": []}
17 11:22:42 =========getscriptScan dict:{}
17 11:22:42 =========getNewDevices scan result:{}
17 11:22:52 in loop #8
17 11:23:03 in loop #9
17 11:23:05 CONFIG: check for new devices every    60 minutes
17 11:23:05 CONFIG: path To python3                /usr/bin/python3
17 11:23:13 in loop #10
17 11:23:23 in loop #11
17 11:23:34 in loop #12
17 11:23:44 in loop #13
17 11:23:55 in loop #14
17 11:24:05 in loop #15
17 11:24:16 in loop #16
17 11:24:26 in loop #17
17 11:24:37 in loop #18
17 11:24:47 in loop #19
17 11:24:58 in loop #20
Sun Jul 18, 2021 2:53 am
Sorry. But I can’t do anything while I am out of town.
Sun Jul 18, 2021 8:32 am
srkinard offline
No worries...was just updating and posting before I forget so it's here whenever. Absolutely no rush or anything.
Sun Jul 18, 2021 9:37 am
..and for the new version of the plugin you need to also update the program from GitHub for appletv. They changed the format of the data and calls
Mon Jul 19, 2021 11:58 pm
And you could power cycle the Apple TV.
