Apple TV Plugin: new versions
Sat Mar 27, 2021 7:18 pm
changes in V 0.3.2@ 2021-03-27
1. changed to continuous listening process for changes of playing xxx
this is much more stable than the previous polling version
2. added a lot of check in case something has an exception
- delete a device, change the ip number
3. added several menu explanations
next steps:
- send commands - power on/off/ start/ stop play etc
changes in V 0.1.1@ 2021-03-26
1. first version:
will scan for apple tv devices every xx minutes
will read play status of ided apple tv devices ever xx secs
Configure in config:
- path to python
- time for scan and read sequences
In device edit the IP numebr can be over written
In menu a manual scan for new devices can be initated
download at https://www.indigodomo.com/pluginstore/248/
Sun Mar 28, 2021 12:05 am
Re: Apple TV Plugin: new versions
this is now 80% functional.. can retrieve all info and "press" all apple remote button
changes in V 0.5.2@ 2021-03-28
1. added menu and actions (Send command to apple tv)
     down             Press key down
     home             Press key home
     home_hold        Hold key home
     left             Press key left
     menu             Press key menu
     next             Press key next
     pause            Press key play
     play             Press key play
     play_pause       Toggle between play and pause
     previous         Press key previous
     right            Press key right
     select           Press key select
     set_position     Seek in the current playing media
     set_repeat       Change repeat state
     set_shuffle      Change shuffle mode to on or off
     skip_backward    Skip backwards a time interval
     skip_forward     Skip forward a time interval
     stop             Press key stop
     suspend          Suspend the device
     top_menu         Go to main menu (long press menu)
     up               Press key up
     volume_down      Press key volume down
     volume_up        Press key volume up
     wakeup           Wake up the device
     power_state      Return device power state
     turn_off         Turn device off
     turn_on          Turn device on
next function:
send play xx commands like play song or http ref.
Sun Mar 28, 2021 6:31 am
changes in V 0.5.4@ 2021-03-28
1. fixed
error=u'MRPCredentials'
tuple index out of range
Sun Mar 28, 2021 9:59 am
changes in V 0.6.4@ 2021-03-28
1. added
   print parameters and devices to logfile
   (un)ignore devices ie ignore certain ip numbers
Sun Mar 28, 2021 5:25 pm
changes in V 0.7.5@ 2021-03-28
1.added free text commands - you can send several commands in one eg 'turn_on delay=1000 play'
2.added print help menu command, gives a long list of how to install, how to use etc.
this version should be ok as a beta, not alpha any more
Mon Mar 29, 2021 7:21 pm
changes in V 1.0.6@ 2021-03-29
1. cosmetic changes in menus
2. added print help to logfile in menu
3. added check if python3 is properly installed
first non beta release
Fri Apr 16, 2021 1:24 pm
changes in V 1.0.9@ 2021-04-16
1. changed steup for default values in plugin.config
2. added addition try except for new devices, in case of bad data return
3. cosmetic changes in menus
4. added print help to logfile in menu
5. added check if python3 is properly installed
Fri Apr 30, 2021 5:33 pm
changes in V 1.0.10@ 2021-04-30
1. when python3 is not installed don't go to sleep in startup, but in concurrent loop
that allows to set config
Sat May 01, 2021 8:02 am
changes in v1.0.12@ 2021-05-01
1. updated help texts to reflect: do not create apple tv devices manually, all done by the plugin automatically
Sat May 01, 2021 4:15 pm
changes in v1.0.14@ 2021-05-01
1. will now try to auto detect path to python3,
will exit after 3 minutes if still not found / defined.
during these 3 minutes you can setup python3 or set the path to python3 in config
appleTV Warning                 ==== python3 path not setup, trying to find path to python3 ====
appleTV                         ==== ... found, setting path to python3 to: >>/usr/local/bin/python3<<
and if not found:
appleTV Warning                 python3 ><  is not present on this mac, see logfile on how to install python3, you have 180 secs to setup config
2. will show a detailed message in indigo log for each new apple device created
appleTV Warning                 =====================================================================================================================================
appleTV                         == New apple tv device created:"appletv_192.168.1.47"; with MAC#:D0:D2:B0:88:7B:77; NO FURTHER action needed to activat/use device ==
appleTV                         == check "plugin/menu/PRINT help to logfile" for available actions etc. ==
SQL Logger                      creating table device_history_1198576866 for "appletv_192.168.1.47"
Sat Jun 12, 2021 10:58 am
changes in v1.1.14@ 2021-05-01
1. upgraded to the march 2021 version of pyatv
install w:
sudo pip3 install pyatv
or download the zipfile and
cd ~/Downloads/pyatv-master/setup.py
sudo python3 setup.py install
if you get an error msg when you run the plugin:
  "ModuleNotFoundError: No module named 'pendulum'"
you need to add in a terminal (or just install them anyway, should not harm)
sudo pip3 install pendulum
sudo pip3 install bidict
sudo pip3 install more_itertools
sudo pip3 install bitstruct
This new version might not work w the older pyatv GitHub download
