AppleTV Plugin not finding any devices
Fri Jun 11, 2021 9:25 am
Re: AppleTV Plugin not finding any devices
yes you might be right, I did install Xcode on my indigo client
/usr/bin/xcodebuild -version
Xcode 12.5
Build version 12E262
I will update my how to post
Fri Jun 11, 2021 10:49 am
danieljmorel offline
After entering the 1st commands into terminal and restarting my computer, here is what I got for the which and --versions commands I received in terminal:
djm@WorkOutNW ~ % which python
which python3
python --version
python3 --version
/usr/bin/python
/usr/bin/python3
Python 2.7.16
Python 3.8.2
djm@WorkOutNW ~ %
Fri Jun 11, 2021 11:33 am
Looks like you are all set then?
The python versions 2.7.16 and 3.8.2 look like the Mac versions as they are using the system /usr/bin/ directories.
Fri Jun 11, 2021 11:39 am
Xcode 12.5
Actually Karl, I think are correct about python 3 being installed by default on MacOS Big Sur. :oops:
I can confirm that is isn't in the beta of MacOS Monterey which I installed on my MacBook Pro this morning..
When you type python3 into a terminal session on MacOS Monterey, it asks if you want to install Xcode developer tools.
When you do that, python 3 is installed (same version 3.8.2) as part of the Xcode Developer Tools install.
So it looks like it is changing (as they said it would) for the next version of MacOS. :)
Fri Jun 11, 2021 12:11 pm
When you do that, python 3 is installed (same version 3.8.2) as part of the Xcode Developer Tools install.)
I'm maybe 80% sure that this is the way it works in Big Sur as well. My Big Sur install has 2 version of Python 3 installed, but neither is the version that you guys are referencing. Both are in fact versions I explicitly installed from python.org (via their respective installers). I surmise that I didn't run the python3 command BEFORE I manually installed those other versions, so therefore didn't get prompted to install from the developer tools. Again, I'm not positive, but I'm pretty sure that's what happened.
MightyMini-2:bin jay$ ls /Library/Frameworks/Python.framework/Versions/
3.6   3.7
Fri Jun 11, 2021 7:57 pm
so I tried to scan for new devices and I still get:
11 21:56:35 =========getscriptScan out:('', 'Traceback (most recent call last):\n File "/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/appleTV.indigoPlugin/Contents/Server Plugin/atvscript.py", line 13, in <module>\n from pyatv import connect, const, scan\nModuleNotFoundError: No module named \'pyatv\'\n')
11 21:56:35 =========getNewDevices scan result:{}
11 21:56:45 in loop #4
any other suggestions or opinions?
Fri Jun 11, 2021 9:11 pm
could you open a terminal and copy and paste
python3
exit()
you should either see:
:python3
Python 3.8.2 (default, Apr  8 2021, 23:19:18)
[Clang 12.0.5 (clang-1205.0.22.9)] on darwin
Type "help", "copyright", "credits" or "license" for more information.
exit()
>>> exit()
or
python3
>>> from pyatvx import connect
  File "<stdin>", line 1, in <module>
ModuleNotFoundError: No module named 'pyatv'
>>> exit()
if you see the second option, the installation is different: my problem.
if you see the first one, your setup is screwy
Sat Jun 12, 2021 6:58 am
Sorry Karl. Looks like the second one:
djm@WorkOutNW ~ % python3
>>> exit()
djm@WorkOutNW ~ %
Sat Jun 12, 2021 7:01 am
where my just says: (no "x")
Sat Jun 12, 2021 7:35 am
To help out with testing, I have just installed the plugin. :)
I was having difficulties getting it to scan for my Apple TV; it wasn't finding it.
So I executed the python 3 atvscript.py script in a terminal window.
Doing this, I am also getting the error:
Looking at the plugin contents, I can't see that it is included. :|
Sat Jun 12, 2021 7:37 am
There seems to be a new version on git hub for atv.
I will download it and check what has changed.
Sat Jun 12, 2021 7:54 am
could this be part of the problem? When I open a terminal window and change the directory to /usr/bin and do an ls I get:
djm@WorkOutNW ~ % cd /usr
djm@WorkOutNW /usr % ls
X11 bin libexec sbin standalone
X11R6 lib local share
djm@WorkOutNW /usr % cd /bin
djm@WorkOutNW /bin % ls
[ dd launchctl pwd test
bash df link rm unlink
cat echo ln rmdir wait4path
chmod ed ls sh zsh
cp expr mkdir sleep
csh hostname mv stty
dash kill pax sync
date ksh ps tcsh
No Python3 listed however Indigo thinks that it in that directory because the configuration does not say "does not exist"
When I go to finder and go to /usr/bin I see Python3 and when I double click it, it opens but I get:
Last login: Sat Jun 12 09:43:11 on ttys001
/usr/bin/python3 ; exit;
djm@WorkOutNW ~ % /usr/bin/python3 ; exit;
This is very similar to the 1st option that was said to be screwy.
Do I need to re-install Python 3.8.2? If so, is it possible? How?
Sat Jun 12, 2021 7:58 am
Please excuse my newbness and the formatting on that last post. Please let me know if you would like me to stop poking around. I really do appreciate all the help on this. Thank you!
Sat Jun 12, 2021 8:25 am
right now it have to check out the new version of atv
I will post a new version of the plugin that supports the new atv
wait until then
Sat Jun 12, 2021 10:59 am
please try V 1.1.14
you might need to add some additional pip3 installs
sudo pip3 install pendulum
sudo pip3 install bidict
sudo pip3 install more_itertools
sudo pip3 install bitstruct
