AppleTV Plugin not finding any devices
Tue Jun 08, 2021 2:20 pm
danieljmorel offline
Re: AppleTV Plugin not finding any devices
It looked like that worked. Was it supposed to add the apple TV's to my Indigo devices. If so, there were no devices added.
Tue Jun 08, 2021 2:37 pm
No that was just the program that us called by the plugin
Then the plugin reads the output and creates the indigo devices.
Can you try
Put the python 3 string back into config
Then run scan again in the plugin.
Tue Jun 08, 2021 3:39 pm
I changed the configuration to /usr/bin/python3 and this is what shows in the log file:
08 17:37:34 CONFIG: path To python3 /usr/bin/python3
08 17:37:43 in loop #18218
08 17:37:53 in loop #18219
08 17:37:53 =========getscriptScan cmd:[u'/usr/bin/python3', '/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/appleTV.indigoPlugin/Contents/Server Plugin/atvscript.py', 'scan']
08 17:37:53 =========getscriptScan out:('', 'Traceback (most recent call last):\n File "/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/appleTV.indigoPlugin/Contents/Server Plugin/atvscript.py", line 13, in <module>\n from pyatv import connect, const, scan\nModuleNotFoundError: No module named \'pyatv\'\n')
08 17:37:53 =========getNewDevices scan result:{}
08 17:38:03 in loop #18220
08 17:38:03 =========getscriptScan cmd:[u'/usr/bin/python3', '/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/appleTV.indigoPlugin/Contents/Server Plugin/atvscript.py', 'scan']
08 17:38:04 =========getscriptScan out:('', 'Traceback (most recent call last):\n File "/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/appleTV.indigoPlugin/Contents/Server Plugin/atvscript.py", line 13, in <module>\n from pyatv import connect, const, scan\nModuleNotFoundError: No module named \'pyatv\'\n')
08 17:38:04 =========getNewDevices scan result:{}
08 17:38:14 in loop #18221
08 17:38:24 in loop #18222
Tue Jun 08, 2021 3:45 pm
Can you put the full string string not just the short version.
Tue Jun 08, 2021 4:24 pm
Would this be the full string:
/Library/Frameworks/Python.framework/Versions/3.9/bin/python3
My apologies for my newbness
Tue Jun 08, 2021 4:26 pm
if so, this is what I get:
08 18:25:08 =========getscriptScan cmd:[u'/Library/Frameworks/Python.framework/Versions/3.9/bin/python3', '/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/appleTV.indigoPlugin/Contents/Server Plugin/atvscript.py', 'scan']
08 18:25:09 =========getscriptScan out:('', 'Traceback (most recent call last):\n File "/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/appleTV.indigoPlugin/Contents/Server Plugin/atvscript.py", line 13, in <module>\n from pyatv import connect, const, scan\n File "/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/pyatv/__init__.py", line 10, in <module>\n from pyatv import conf, exceptions, interface\n File "/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/pyatv/conf.py", line 16, in <module>\n from pyatv.interface import BaseService, DeviceInfo\n File "/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/pyatv/interface.py", line 37, in <module>\n from pyatv.support import net\n File "/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/pyatv/support/net.py", line 10, in <module>\n import netifaces\nImportError: dlopen(/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/netifaces.cpython-39-darwin.so, 2): no suitable image found. Did find:\n\t/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/netifaces.cpython-39-darwin.so: mach-o, but wrong architecture\n\t/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/netifaces.cpython-39-darwin.so: mach-o, but wrong architecture\n')
08 18:25:09 =========getNewDevices scan result:{}
08 18:25:19 in loop #18502
Tue Jun 08, 2021 4:42 pm
Is this the same machine?
Ie Indigo server / client ?
Have no clue what is different.
Is there another python 3 in that machine ?
Tue Jun 08, 2021 4:56 pm
This is the same machine - Server / Client
As far as I know all I only have is one installation of Python 3.
Terminals "which Python3" shows:
djm@WorkOutNW ~ % which python3
/usr/bin/python
djm@WorkOutNW ~ %
should I try to uninstall Python3?
Tue Jun 08, 2021 5:33 pm
It appears that it is looking for a module pyatv but there is none found. should there be a file called pyatv and if so where should it be located.
08 19:31:49 =========getscriptScan cmd:[u'/usr/bin/python3', '/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/appleTV.indigoPlugin/Contents/Server Plugin/atvscript.py', 'scan']
08 19:31:49 =========getscriptScan out:('', 'Traceback (most recent call last):\n File "/Library/Application Support/Perceptive Automation/Indigo 7.5/Plugins/appleTV.indigoPlugin/Contents/Server Plugin/atvscript.py", line 13, in <module>\n from pyatv import connect, const, scan\nModuleNotFoundError: No module named \'pyatv\'\n')
08 19:31:49 =========getNewDevices scan result:{}
08 19:31:59 in loop #18900
Tue Jun 08, 2021 5:36 pm
When I try to re-install pyatv this is what I get:
djm@WorkOutNW ~ % pip3 install pyatv
Requirement already satisfied: pyatv in /Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages (0.7.7)
Requirement already satisfied: zeroconf>=0.28.0 in /Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages (from pyatv) (0.31.0)
Requirement already satisfied: cryptography>=2.6 in /Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages (from pyatv) (3.4.7)
Requirement already satisfied: netifaces>=0.10.0 in /Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages (from pyatv) (0.11.0)
Requirement already satisfied: aiohttp<5,>=3.1.0 in /Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages (from pyatv) (3.7.4.post0)
Requirement already satisfied: protobuf<4,>=3.6.0 in /Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages (from pyatv) (3.17.2)
Requirement already satisfied: srptools>=0.2.0 in /Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages (from pyatv) (1.0.1)
Requirement already satisfied: multidict<7.0,>=4.5 in /Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages (from aiohttp<5,>=3.1.0->pyatv) (5.1.0)
Requirement already satisfied: attrs>=17.3.0 in /Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages (from aiohttp<5,>=3.1.0->pyatv) (21.2.0)
Requirement already satisfied: async-timeout<4.0,>=3.0 in /Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages (from aiohttp<5,>=3.1.0->pyatv) (3.0.1)
Requirement already satisfied: yarl<2.0,>=1.0 in /Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages (from aiohttp<5,>=3.1.0->pyatv) (1.6.3)
Requirement already satisfied: chardet<5.0,>=2.0 in /Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages (from aiohttp<5,>=3.1.0->pyatv) (4.0.0)
Requirement already satisfied: typing-extensions>=3.6.5 in /Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages (from aiohttp<5,>=3.1.0->pyatv) (3.10.0.0)
Requirement already satisfied: cffi>=1.12 in /Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages (from cryptography>=2.6->pyatv) (1.14.5)
Requirement already satisfied: pycparser in /Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages (from cffi>=1.12->cryptography>=2.6->pyatv) (2.20)
Requirement already satisfied: six>=1.9 in /Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages (from protobuf<4,>=3.6.0->pyatv) (1.16.0)
Requirement already satisfied: idna>=2.0 in /Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages (from yarl<2.0,>=1.0->aiohttp<5,>=3.1.0->pyatv) (3.2)
Requirement already satisfied: ifaddr>=0.1.7 in /Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages (from zeroconf>=0.28.0->pyatv) (0.1.7)
djm@WorkOutNW ~ %
Tue Jun 08, 2021 5:42 pm
Is there possibly another option for getting the Apple TV's added to Indigo's devices?
Tue Jun 08, 2021 5:54 pm
It is not just adding the indigo devices. Likely also all other function will not work as they use similar calls.
I will Play around a little.
What is your opsys? Mac version ?
Tue Jun 08, 2021 5:55 pm
And could you do
Open terminal
echo $PATH
Tue Jun 08, 2021 6:00 pm
Big Sur
Version: 11.4
Tue Jun 08, 2021 6:01 pm
djm@WorkOutNW ~ % echo $PATH
/Library/Frameworks/Python.framework/Versions/3.9/bin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/Library/Apple/usr/bin
djm@WorkOutNW ~ %
