"Task was destroyed but it is pending!"
Fri Apr 16, 2021 11:24 am
ukie offline
Thank you for a great plugin!
I have 3 ATV connected, 2 4K devices and one HD. For the most part everything works as expected.
However, one of the 4K devices seems to be having some issues.
While it basically works, the status keeps cycling between "idle/playing/etc." and "Task was destroyed but it is pending!" (in red).
When the plugin is relaunched, the Event Log indicates "appleTV Error in Line 897 has error=u'192.168.1.75'"
It also is not able to retrieve the MAC address and some of the parameters seem to be off.
The other 4K and HD ATVs do not do this. All are running the latest 14.4 TvOS, but the one that is acting up does not show the OS version under Indigo.
Any thoughts?
Fri Apr 16, 2021 1:03 pm
Re:
Try to power cycle the tv
.. and try v 1.0.9 has some more debug statements in case of errors
Sun Apr 18, 2021 9:00 pm
Re: "Task was destroyed but it is pending!"
Could you test the new version and power cycle the Apple TV?
