Hubitat Bridge Version 0.5.7 Update
Fri Aug 27, 2021 9:16 am
Version 0.5.7 of the plugin is now available in the Indigo Plugin Store.
Changes since release Version 0.5.4 include:
  • A new action Set White Level / Temperature to enable independent control of a device's White Level and White Temperature.
  • The update also includes miscellaneous bug fixes.
You can find the new action by going to:
Device Actions > Hubitat Bridge Controls > Set White Level / Temperature
Edit the Action settings which will display a simple dialogue to enable you to select one or more of White Level and White Temperature to update. Enter the appropriate value(s) in the revealed field when an option is ticked.
This Action is just in addition to the standard Set RGBW Levels action, giving you finer control of White. :)
