Hubitat Bridge Now Available In Indigo Plugin Store
Mon Jun 21, 2021 3:32 am
autolog offline
The Hubitat Bridge Plugin is now available in the Indigo Plugin Store.
In summary, this plugin gives you the capability to access additional Zigbee and Z-Wave devices attached to the Hubitat Elevation hub and have their states reflected in Indigo. Likewise, you can control these devices via Indigo.
I now have all my Zigbee devices connected to to my Hubitat Elevation Hub and directly accessible and controllable from Indigo. :)
It will only run on Indigo 2021.1 or later.
The plugin now has hybrid support for Athome Tasmota plugs (UK). It supports the plugs directly via MQTT and does not need a Hubitat Elevation Hub to control them. It may support Athome Tasmota plugs from other regions but hasn't been tested.
I am open to extending this feature if requested.
Documentation is still being worked on. Please post any questions to this forum.
Finally, a big call out to Clive (@CliveS) for his help with alpha/beta testing this plugin. :D
