To get started with this plugin you need to have / do the following (overview):
- A Hubitat Elevation Hub
- An MQTT Broker (suggest Mosquitto running in a Docker container)
- Install the MQTT App from @kevin aka xAPPO on Github: Forum: [Beta] MQTT beta 3d (released 5th July) and Github: xAPPO/MQTT
- Configure the MQTT App to publish Hubitat devices you want to monitor / control
- Install the Hubitat Bridge plugin, add in a Hubitat Elevation device, then add Hubitat devices associated with those published via MQTT
As an aside, I am reluctant to get too involved with explaining how to configure and setup Hubitat unless it is related to this plugin.
Questions on specifics about Hubitat are best directed to the Hubitat forums.
Over the next few weeks I will add a documentation wiki to the Github repository that will explain in more detail how to set this up.
In the meanwhile, be sure to ask questions so that they can either be answered or pointed in the right direction to get the info needed.
