Insteon KeypadLinc Replacement
Mon Feb 08, 2021 5:59 pm
timrowledge offline
I haven't seen any non-Insteon switch that has anything close to the 8 button SwitchLinc. There are several places where I use all 5 actions of a 6-button, ie the main on/off + 4 buttons. If it were really compelling I could probably be persuaded to install two switches, though obviously it would be a bit of a faff to cut holes in wall etc.
What *would* be nice is a multi-action switch that has actual on-off buttons instead of an on, an off and four toggle buttons. Nice would be switches that are purely controllers and completely separate dimmer/contactors.
Of course, appropriate quality listing - in the US & Canada I guess that means 'UL Listing' - is essential. My insurance (and probably yours) would not pay out if a non-listed device set fire to the house.
[MODERATOR NOTE]: split this off from the original post and created a new topic.
Mon Feb 08, 2021 9:30 pm
Re: Replacing Insteon
timrowledge wrote:
For example, I haven't seen any non-Insteon switch that has anything close to the 8 button SwitchLinc. There are several places where I use all 5 actions of a 6-button, ie the main on/off + 4 buttons. If it were really compelling I could probably be persuaded to install two switches, though obviously it would be a bit of a faff to cut holes in wall etc.
Closest I know of is the Lutron RRa2 keypads, like this. You can program them to do specific devices or scenes using the Lutron software, or you can use the plugin and do all sorts of multi-press triggers.
Tue Feb 09, 2021 5:35 am
bschollnick2 offline
Can you spare a link to the Lutron RRA2 keypad? I can't find it on Amazon, and I'm curious about the pricing...
My Plugins for Indigo (v4, v5, and v6) - http://bit.ly/U8XxPG
Security Script for v4 - http://bit.ly/QTgclf
for v5 - http://bit.ly/T6WBKu
Support Forum(s) - http://www.perceptiveautomation.com/userforum/viewforum.php?f=33
Tue Feb 09, 2021 6:40 am
RRA2 gear is not advertised on-line, except maybe on eBay. It's distributor only. I get mine from http://hankselectric.supply, I can give you a contact there.
It's not cheap. Keypads are $200-$250 each. Dimmers about $100.
Fri Feb 12, 2021 2:37 pm
timrowledge offline
Re: Insteon KeypadLinc Replacement
Ouch. That's expensive.
Fri Feb 12, 2021 2:56 pm
Commercial quality gear isn't cheap. It's in the same price range as Control4 or Crestron or any of the other commercial solutions. You get what you pay for.
Tue Feb 23, 2021 8:25 pm
whmoorejr offline
I tested out the GE Quad Scene device as a possible replacement for my aging keypad link devices... Long story short, didn't work.
Product: https://www.amazon.com/GE-Enbrighten-34176-Portable-One-Touch/dp/B084N5H4SC
Forum discussion: https://forums.indigodomo.com/viewtopic.php?f=58&t=24592&p=197234&hilit=GE+Quad#p197234
For me, when the price goes past a certain point on a controller, I can't help but to compare it against the cost of a mounted android device running a dedicated control page with domopad.
In one situation, I have gone to a standard(ish) 3-way set-up, (my living room fan). A switch on either side of the room for the fan, one actually connected to the load, the other switch has the load capped and I use triggers to keep it in sync with the actual switch(both are z-wave switches). To change speeds, I have to use voice (Alexa via node-red) or through indigo-touch or another indigo control page. I would prefer to have all speed selections physically there, but I haven't found a z-wave alternative I like as much and I still have a few spare keypad links in a box to keep me going.
I could use the scene feature of my z-wave switches to change fan speed. (hold, tap, double-tap, triple-tap, etc.) but with a house full of kids and a spouse that doesn't fully appreciate my nerd-side, I've only done scene controlling on the switches in my office.
Bill
My Plugin: My People
Wed Feb 24, 2021 10:56 am
For fan control, you might consider the HomeSeer Fan Controller, which will work with their 3-way Companion Switch. I've not personally used this combination, but I do have one fan controller that seems pretty reliable.
Thu Feb 25, 2021 12:03 pm
Korey offline
I have a Buddy that put older C4 gear into his home, he bought everything used and has figured a way to activate the software so he can program it.
He uses these older keypads
He tells me there are Zigbee, I wonder if there is a way to adopt them into the Zigbee Plugin and utilize them. :?:
Seems Indigo could benefit from a plugin that "speaks" whatever protocols Control4 and Crestron use, so we could buy up the old pro hardware that is quite cheap on Ebay all the time.
Korey
