- icon.png (282.86 KiB) Viewed 4322 times
https://www.indigodomo.com/pluginstore/244/https://github.com/whmoorejr/My-People/releases/tag/1.2.90Introducing my first ever Plugin... "My People".
The amazing thing.... it does nothing. It is really a way to organize people data in a way that can be used by scripting or by other plugins. Each My People "Person" device has multiple states that can be set from the plugin using actions.
So, use your favorite plugin or method to determine occupancy and use that to trigger your person's state to (Home, Away or Unsure).
Use your person's email address for all of your scripts that email you something. Now if your email changes, you don't have to edit all those scripts, just your person data field, state id=email1Address.
Lastly, this makes it easier to make a control page with person data. Copy-paste the person device on your control page and just switch the State you want reflected.
Step 1: Configure the "Person" Device:
- MyPeople_Config.png (52.29 KiB) Viewed 4322 times
Step 2: Use Actions to populate device states:
- MyPeople_Actions.png (161.99 KiB) Viewed 4322 times
Step 3: Use Triggers with this plugin to fire off other stuff:
- MyPeople_Triggers.png (188.04 KiB) Viewed 4322 times
Step 4: Note the custom device states from the main UI:
- MyPeople_MainUI.png (62.07 KiB) Viewed 4322 times
