I have no idea why this is happening. I've tweaked the code a bit to try to keep the plugin from crashing when it happens:
https://github.com/FlyingDiver/Indigo-m ... /tag/0.1.4
Feb 7, 2022 at 11:46:01 AM
miniUniFi Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 126, in runConcurrentThread
File "plugin.py", line 438, in updateUniFiDevice
StandardError: ServerCommunicationError -- timeout waiting for response
miniUniFi Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Trigger Washing Machine Active
Feb 7, 2022 at 11:47:55 AM
Sonos Error Error in plugin execution runConcurrentThread:
File "/Library/Application Support/Perceptive Automation/Indigo 2021.2/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 384, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 2021.2/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 634, in updateRelTime
Sonos Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
AD2USB Alarm Interface Error Error on line 749
AD2USB Alarm Interface Error panelMsgRead: Error: ServerCommunicationError -- timeout waiting for response
Sonos SoCo Reactor Ignition...
Indigo Cocoa client disconnected (192.168.0.13)
Feb 7, 2022 at 11:48:41 AM
Z-Wave received "Garage Temp" sensor update to 50.5 °F
FlyingDiver wrote:Do you have both ethernet and Wifi enabled on this machine at the same time? That's usually not a good idea. If only one, then switching to the other might provide useful info.
FlyingDiver wrote:Also, check Console.app to see if there's any significant errors being reported. There might be something at the OS level at the time this is happening.
2022-02-07 11:45:37.484513 (user/501/com.apple.TrustEvaluationAgent [32236]) <Notice>: service exited: dirty = 0, supported pressured-exit = 0
2022-02-07 11:45:37.484523 (user/501/com.apple.TrustEvaluationAgent [32236]) <Notice>: exited due to exit(0)
2022-02-07 11:45:37.484525 (user/501/com.apple.TrustEvaluationAgent [32236]) <Notice>: service state: exited
2022-02-07 11:45:37.484528 (user/501/com.apple.TrustEvaluationAgent [32236]) <Notice>: internal event: EXITED, code = 0
2022-02-07 11:45:37.484530 (user/501) <Notice>: service inactive: com.apple.TrustEvaluationAgent
2022-02-07 11:45:37.484539 (user/501/com.apple.TrustEvaluationAgent [32236]) <Notice>: service state: not running
2022-02-07 11:45:47.106773 (user/501) <Warning>: failed lookup: name = com.apple.TrustEvaluationAgent, flags = 0x9, requestor = IndigoPluginHos[31116], error = 1: Operation not permitted
2022-02-07 11:45:47.106802 (gui/501 [100006]) <Warning>: failed lookup: name = com.apple.TrustEvaluationAgent, flags = 0x9, requestor = IndigoPluginHos[31116], error = 1: Operation not permitted
2022-02-07 11:45:47.106970 (user/501/com.apple.TrustEvaluationAgent) <Notice>: internal event: WILL_SPAWN, code = 0
2022-02-07 11:45:47.106978 (user/501/com.apple.TrustEvaluationAgent) <Notice>: service state: spawn scheduled
2022-02-07 11:45:47.106980 (user/501/com.apple.TrustEvaluationAgent) <Notice>: service state: spawning
2022-02-07 11:45:47.106991 (user/501/com.apple.TrustEvaluationAgent) <Notice>: launching: ipc (mach)
2022-02-07 11:45:47.107866 (user/501/com.apple.TrustEvaluationAgent [32241]) <Notice>: xpcproxy spawned with pid 32241
2022-02-07 11:45:47.107879 (user/501/com.apple.TrustEvaluationAgent [32241]) <Notice>: internal event: SPAWNED, code = 0
2022-02-07 11:45:47.107882 (user/501/com.apple.TrustEvaluationAgent [32241]) <Notice>: service state: xpcproxy
2022-02-07 11:45:47.107907 (user/501/com.apple.TrustEvaluationAgent [32241]) <Notice>: internal event: SOURCE_ATTACH, code = 0
2022-02-07 11:45:47.113912 (user/501/com.apple.TrustEvaluationAgent [32241]) <Notice>: service state: running
2022-02-07 11:45:47.113923 (user/501/com.apple.TrustEvaluationAgent [32241]) <Notice>: internal event: INIT, code = 0
2022-02-07 11:45:47.113928 (user/501/com.apple.TrustEvaluationAgent [32241]) <Notice>: Successfully spawned trustevaluationagent[32241] because ipc (mach)
2022-02-07 11:45:47.165083 (user/501) <Warning>: failed lookup: name = com.apple.TrustEvaluationAgent, flags = 0x9, requestor = IndigoPluginHos[31116], error = 1: Operation not permitted
2022-02-07 11:45:47.165097 (gui/501 [100006]) <Warning>: failed lookup: name = com.apple.TrustEvaluationAgent, flags = 0x9, requestor = IndigoPluginHos[31116], error = 1: Operation not permitted
2022-02-07 11:46:07.171555 (user/501/com.apple.TrustEvaluationAgent [32241]) <Notice>: service exited: dirty = 0, supported pressured-exit = 0
2022-02-07 11:46:07.171566 (user/501/com.apple.TrustEvaluationAgent [32241]) <Notice>: exited due to exit(0)
2022-02-07 11:46:07.171569 (user/501/com.apple.TrustEvaluationAgent [32241]) <Notice>: service state: exited
2022-02-07 11:46:07.171571 (user/501/com.apple.TrustEvaluationAgent [32241]) <Notice>: internal event: EXITED, code = 0
2022-02-07 11:46:07.171573 (user/501) <Notice>: service inactive: com.apple.TrustEvaluationAgent
2022-02-07 11:46:07.171583 (user/501/com.apple.TrustEvaluationAgent [32241]) <Notice>: service state: not running
