Config issue
Wed Jun 23, 2021 1:34 pm
roquej offline
Config issue
This is probably user-error, but I have my CloudKey Gen2 configured with local access. No 2FA. However, this stopped working with Indigo 2021.1
I am getting: miniUniFi Warning new device: Unable to determine controller type - using Unifi Standard controller
and the device shows: Login error
Also tested with a regular account, not local, also without 2FA and getting the same error.
Ideas?
JP
Wed Jun 23, 2021 3:47 pm
Re: Config issue
A cloud key is a standard controller, I believe. I think it's only the UDM that's not.
So you're probably getting that error for the same reason you're getting the login error. The username & password aren't working.
It's working fine on both of my systems running 2021.1, so something else broke on your system. Do you have SSL verification enabled? If so, try with it turned off.
Wed Jun 23, 2021 4:14 pm
roquej offline
Config issue
I have tested the local access userid and password several times. I am able to login from a browser with no problem and not getting 2F2 challenged. So, I am using the correct password. Just checked it again right now.
Also, SSL verification is disabled.
Could it be the CloudKey Gen2 appl version? Mine is 6.2.26.
JP
Wed Jun 23, 2021 4:35 pm
Re: Config issue
The docker version of the controller I'm running is still at 6.0.41. I just haven't updated it recently.
In a Terminal window, enter this (with substitutions for your controller config) and report it back here:
 curl -k -v https://IP-ADDRESS:PORT
Wed Jun 23, 2021 4:51 pm
roquej offline
Re: Config issue
Here you go:
   Trying 192.168.X.X...
* TCP_NODELAY set
* Connected to 192.168.X.X (192.168.X.X) port 8443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* successfully set certificate verify locations:
*   CAfile: /etc/ssl/cert.pem
  CApath: none
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
* TLSv1.2 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (IN), TLS handshake, Server key exchange (12):
* TLSv1.2 (IN), TLS handshake, Server finished (14):
* TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
* TLSv1.2 (OUT), TLS change cipher, Change cipher spec (1):
* TLSv1.2 (OUT), TLS handshake, Finished (20):
* TLSv1.2 (IN), TLS change cipher, Change cipher spec (1):
* TLSv1.2 (IN), TLS handshake, Finished (20):
* SSL connection using TLSv1.2 / ECDHE-RSA-AES128-GCM-SHA256
* ALPN, server did not agree to a protocol
* Server certificate:
*  subject: C=US; ST=New York; L=New York; O=Ubiquiti Inc.; OU=UniFi; CN=UniFi
*  start date: Jun  9 00:14:35 2021 GMT
*  expire date: Sep 12 00:14:35 2023 GMT
*  issuer: C=US; ST=New York; L=New York; O=Ubiquiti Inc.; OU=UniFi; CN=UniFi
*  SSL certificate verify result: self signed certificate (18), continuing anyway.
> GET / HTTP/1.1
> Host: 192.168.X.X:8443
> User-Agent: curl/7.64.1
> Accept: */*
< HTTP/1.1 404
< Content-Length: 0
< Date: Wed, 23 Jun 2021 22:50:10 GMT
* Connection #0 to host 192.168.2.9 left intact
* Closing connection 0
Wed Jun 23, 2021 5:52 pm
Re: Config issue
404 is page not found. What's the exact URL you're using in a browser to connect?
Wed Jun 23, 2021 6:01 pm
Re: Config issue
I don't see how the Indigo version could have caused this. Are you sure it was working with Indigo 7.5 and the current CloudKey software? It looks more like that changed.
Wed Jun 23, 2021 6:32 pm
roquej offline
Re: Config issue
I am using http://192.168.X.X and I can login:
Screen Shot 2021-06-23 at 8.29.14 PM.png (191.76 KiB) Viewed 3054 times
Wed Jun 23, 2021 6:35 pm
roquej offline
Re: Config issue
Three things changed within a few days of each other, that I noticed as Unifi is set to update automatically:
1. upgrade to the controller software
2. upgrade to the CloudKey firmware
3. Indigo upgrade
JP
Wed Jun 23, 2021 6:37 pm
Re: Config issue
You're entering http, not https? So there's a redirect going on already.
Also, I've never seen that UI before. But then, I don't have a cloud key. What's the link URL for that Network icon?
I just saw your second post. This is clearly a change to the UBNT software, somehow. I'm not sure how to address this.
Wed Jun 23, 2021 6:45 pm
roquej offline
Re: Config issue
Correct, as I don't have an SSL certificate configured. Is all internal to my home so not really needed.
The URL if the network Item is:
192.168.X.X/network/site/default/dashboard (default)
Also, I have my old CloudKey, before the upgrade to Gen2. If you msg me an address, I will send it your way. I don't need it.
JP
Wed Jun 23, 2021 6:51 pm
Re: Config issue
I'm pretty sure it's redirecting to https anyway. Do you have a lock icon in the browser address field? When I try to connect with http it tells me no. But that might be a specific setting in the UI.
Before you do that, can you hook it up and try to connect to it? What URLs is it using?
Wed Jun 23, 2021 7:30 pm
roquej offline
Re: Config issue
I am glad I checked, can't get my old Gen1 CloudKey to work. Sorry.
However, if upgraded to the latest version, you will see the same screen. Gen1 and Gen2 don't offer any discerning difference from the OS point of view. Gen2 just has an internal battery and a faster processor.
The URL for the devices page is: https://192.168.2.9/network/site/defaul ... list/1/100, when the last number is the number of devices to list. I have it set at 100.
Also, because the SSL certificate isn't installed, the https crossed in by browser.
JP
Wed Jun 23, 2021 7:50 pm
roquej offline
Re: Config issue
I was able to reset the CloudKey. Is working fine again. Here are the screens.
https://192.168.Y.Y
Clicking on manage, you get
https://192.168.Y.Y:8443/manage/site/default/dashboard
JP
Screen Shot 2021-06-23 at 9.49.12 PM.png (424.4 KiB) Viewed 3033 times
Screen Shot 2021-06-23 at 9.41.01 PM.png (447.87 KiB) Viewed 3033 times
Wed Jun 23, 2021 7:55 pm
Re: Config issue
That screen looks like the standard controller that you get with the stand-alone software. Obviously they made some major change to the UI and the same URLs aren't working anymore in the new version. So there's a couple problems. How to identify the version that's currently running, does login work the same, and are the URLs to fetch the data the same as one of the existing methods.
The UBNT Wiki that this code is based on doesn't mention the new UI at all.
It might be worth taking that cloud key if it can be upgraded to the new software version for testing. I'll PM you an address.
