- Posted on
Mon Apr 24, 2023 3:29 am
siclark
offline
Hi Neil, there appears to be an issue with the version of the plugin here and it doesn't work.
Also I now have the Glowmarkt CAD device for local MQTT, and can see the trigger triggering, but I have 142 messages queued and counting, and none appear to be getting read by the device.
Edit: I deleted the plugin and prefs and restarted Indigo and downloaded. I now have the dropdown populated and I can choose the devices, but still get no dat populated in them, and the MQTT device shows CAD Offline / No MQTT Messages.
The Queue is ##GlowmarktCAD_local##
Edit 2: The zip file of the alpha version was good, so I have that running now.
I am now seeing some values populated. I think there are some issues with the device. deviceTypeId maybe, in that running in debug I dont see that populated correctly. and removing that from the IF seems to work, although at risk of other incorrect behaviour.
