Glowmarkt CAD/IHD Plugin Released
Sun Jun 28, 2020 2:39 pm
neilk offline
Hi all,
I have now published this to the Plugin Store, and it seems very stable but it has only been tested by me. This version supports updates via the API which you can get with a "free" account from Glowmarkt, or for real time energy usage direct from your smart meter the MQTT version that requires you to purchase the Glowmarkt IHD/CAD that connects to your UK smart meter. You get real time electricity usage, and near real time cost and usage for electricity and gas. It utilises FlyingDivers excellent MQTT plugin that does the heavy lifting for MQTT.
https://github.com/neilkplugins/Glow-IHD-CAD-indigo-plugin/wiki for the documentation.
Any questions, problems or requests let me know. It also works incredibly well with the Grafana plugin, and I am also embedding the Grafana dials in my control page for energy usage.
Here is the ugly control page
Screenshot 2020-06-28 at 21.29.23.png (92.73 KiB) Viewed 4314 times
and my Grafana Dashboard (not all of it)
Screenshot 2020-06-28 at 21.36.31.png (305.86 KiB) Viewed 4314 times
Just adding some new functionality to the Octopus Energy plugin as well so that it calculates the best time to run a load for 30m, 1hr, 2hr, 3hr or 4hr to get the lowest rates and a new version will be published that also gets at your usage data.
Neil
Sat Jul 04, 2020 5:27 am
neilk offline
Re: Glowmarkt CAD/IHD Plugin Released
https://github.com/neilkplugins/Glow-IHD-CAD-indigo-plugin/releases/download/0.0.12/GlowmarktCAD.indigoPlugin.zip
This version adds no new functionality but adds meaningful state labelling for the device states for each 30min Cost or Consumption status. The initial version each state was labelled "Electricity State" which with 48 of them was not helpful when trying to create control pages. In this version they appear as "Consumption from 00:00" etc, which is a compromise as the same states are used for Cost and Consumption data depending on the device configuration. Given this only impacts Trigger or Control Page state labels it is reasonable but open to other suggestions.
Mon Aug 17, 2020 6:58 am
racarter offline
Hi Neil
Just to let you know I got my EDF smart meters fitted last week and signed up for a Glowmarkt account. My display arrived today and I've now got the plugin up and running. Thanks for all your efforts!
Alan
Mon Aug 17, 2020 11:04 am
neilk offline
Alan,
Thanks for letting me know, I suspect you are user number 1 so please feel free to chip in with requests or I am sure you will find some quirks.
Regards,
Neil
Wed Oct 14, 2020 2:48 pm
neilk offline
Alan (or any other users),
I had an issue yesterday and I wonder if you have experienced it. The MQTT messages were not being consumed and I ended up with 40k+ messages, that flushed through when it restarted. I have only seen this once and wondered if you have seen anything similar.
Neil
Wed Oct 14, 2020 3:56 pm
racarter offline
Hi Neil
No, I've never seen that issue. The only one I have is occasional 1-2 minute bursts of
GlowmarktCAD Error Failed to complete updates for Glow device Glow Energy
but I assume that's just their servers not responding quickly enough (or at all) for a short while.
Thu Oct 15, 2020 8:11 am
neilk offline
Alan,
Thanks, I recently had them push the agile screen (you have to request it) to my IHD and suspect that may have triggered the issue, I will also see if I can better trap that error as I see it occasionally as well and I think it may be a malformed MQTT payload, or at least one I don’t parse properly.
Neil
Fri Oct 23, 2020 4:01 am
racarter offline
Hi Neil
Had a few of these today:
23 Oct 2020 at 09:41:48
GlowmarktCAD Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 236, in runConcurrentThread
File "plugin.py", line 313, in update
File "plugin.py", line 62, in refresh_daily_consumption_device
UnboundLocalError: local variable 'response' referenced before assignment
GlowmarktCAD Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Fri Oct 23, 2020 5:58 am
neilk offline
Hi Alan,
I will take a look over the weekend, I had the same and suspect I am not catching an unexpected API response (or lack of one) correctly. I had some other weirdness late last night when my ZWave network went unresponsive and other plugins went crazy and I thought it may have been that so this is useful to know.
Neil
Fri Oct 23, 2020 6:28 am
neilk offline
It looks as expected as the API had a couple of wobbles this morning and I don’t trap it correctly but will work a fix. I will need to keep a close eye on this on Saturday as the clocks go back as well as this will be uncharted territory for me and the energy API’s are known to be challenging, not to mention my novice skills :D
Fri Oct 23, 2020 6:39 am
racarter offline
:D Good luck!
Sat Oct 24, 2020 4:41 am
neilk offline
I have just pushed 0.0.13 to the plugin store that addresses the issue to trap and more elegantly recover from API refresh issue. This issue may surface in other API accesses, and I will review the remaining code, but this addresses the most frequent potential issue and once the clocks change tonight in case anything else is needed to be updated.
Neil
Sat Oct 24, 2020 5:02 am
racarter offline
Thanks Neil - I’ll install it this afternoon.
