Hi whmoorejr:
The documentation for the plugin has a couple examples on the
tutorials page and more will be added over time -- including video examples of how to use features of the plugin and Touch Portal pages in action. there is definitely more to come.
The plugin isn't meant to be a replacement for Indigo Control Pages, but rather a bridge for those that want to use Touch Portal and move data and access functions between Touch Portal and Indigo. Touch Portal has functions built in to share pages and icons with other users, but that feature is complicated because my setup is linked to my Indigo devices and wouldn't work for you without some effort. Here is a snapshot of a simple device that I use to turn on and off a feature light in our living room. This is a very simple example, but that's because I keep deleting my entire setup for testing new code during development.
- 1596301357992.png (134.16 KiB) Viewed 2539 times
One primary feature that Touch Portal brings is the ability to integrate and interface with other functions on the Indigo server machine. For example, with Touch Portal, you can:
- Start an application
- Run a bash file
- Simulate key presses
- Simulate mouse clicks
- change button visuals based on conditions
- File I/O
- HTTP Get/Post/Put
To name a few.
What we have so far works great, but it's just scratching the surface and more features are being added to Touch Portal all the time. Also, we haven't even gotten into the idea of linking Indigo with other Touch Portal plugins. For example, you could create a macro that changes the brightness and color of an RGB light bulb as more viewers join your Twitch Stream!
