Variables Sync
Wed Jan 19, 2022 1:23 pm
vtmikel offline
Variables Sync
Hi-
Just started using your plugin more substantially. I noticed two things:
1. If you configure the plugin with variables only, no devices, the changes to the variables do not get published to MQTT/HA
2. If a variable gets changed to a value with a capitol letter "True" or "False", the change is either not propagated, or it's not interpreted correctly. Changing to lower case corrects the problem. The problem here is that some other plugins are changing the variables where I'm not in control of the case sensitivity.
Thanks again for the plugin.
Mike
