Plugin Error
Thu Jul 30, 2020 10:26 pm
bigballer2k offline
Plugin Error
Every time I try to start the plugin, I get the following error which prevents it from starting and allowing me access to the configuration screen. I've tried disabling the plugin as well as deleting and re-installing but have not yet figured out how to get it to work.
Reloading plugin "HassBridge 1.2.2"
Starting plugin "HassBridge 1.2.2" (pid 13041)
HassBridge Error Error in plugin execution InitializeMain:
File "plugin.py", line 93, in __init__
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/HassBridge.indigoPlugin/Contents/Server Plugin/__init__.py", line 53, in __init__
ValueError: invalid literal for int() with base 10: ''
Stopping plugin "HassBridge 1.2.2" (pid 13041)
Stopped plugin "HassBridge 1.2.2"
Fri Jul 31, 2020 8:17 am
WonderSlug offline
Re: Plugin Error
Howdy,
Try looking at your config at the MQTT server port. Make sure it doesn't have a space or something odd in it. That line the error is happening will fail if there is non number characters in there.
I will look at adding some better config validation as well.
Mon Sep 28, 2020 10:00 pm
bigballer2k offline
Re: Plugin Error
I haven't looked at this in a while but when I did a few weeks ago it hit me to wonder if they reason I was getting that error message was because my home assistant instance is running on a raspberry pi whereas indigo is running on my MacBook pro. Do they need to be running on the same system for this plugin to work?
Tue Oct 06, 2020 8:56 am
WonderSlug offline
Re: Plugin Error
No it works fine between machines. I run my indigo mac-mini and all of my home assistant stuff on a intel nuc. A raspberry pi would work fine as well.
