HassBridge makes Virtual Device a binary sensor
Tue May 19, 2020 9:38 am
dproctor offline
In V1.2.1 of HassBridge, my virtual device (Device Group type) show up in Home Assistant as a binary sensor instead of a switch. I have troubleshot it to an issue with the fact that this particular virtual device (device group) in Indigo controls both a dimmer and a switch. If I change that virtual device to only control dimmers or only control switches then the virtual device shows up correctly in Home Assistant. I have downgraded to v1.2.0 and the issue goes away, ie the virtual device that has both the dimmer and switch shows up as a switch in HA.
Tue May 19, 2020 2:51 pm
WonderSlug offline
Re: HassBridge makes Virtual Device a binary sensor
Ok found the bug.
Being tracked here: https://github.com/wonderslug/hassbridge/issues/11
Sun May 24, 2020 12:40 pm
WonderSlug offline
Should be fixed in v1.2.2
