HassBridge plugin
Mon May 11, 2020 7:24 pm
farberm offline
Re: HassBridge plugin
I am getting this error about SSL handshake. Any suggestions. Config file included
Not sure what is wrong with my config?
HassBridge Connecting to the MQTT Server...
HassBridge Connected to MQTT Server!
HassBridge Error Exception trapped:HTTPSConnectionPool(host='192.168.2.113', port=8123): Max retries exceeded with url: /api/states (Caused by SSLError(SSLError("bad handshake: Error([('SSL routines', 'ssl3_get_record', 'wrong version number')],)",),))
HassBridge Error Error in plugin execution UiClosed1:
File "plugin.py", line 149, in closedPrefsConfigUi
File "plugin.py", line 131, in update_perfs
File "plugin.py", line 347, in _setup_ha_devices
File "plugin.py", line 444, in _refresh_ha_info
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/HassBridge.indigoPlugin/Contents/Server Plugin/libs/requests/api.py", line 61, in request
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/HassBridge.indigoPlugin/Contents/Server Plugin/libs/requests/sessions.py", line 530, in request
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/HassBridge.indigoPlugin/Contents/Server Plugin/libs/requests/sessions.py", line 643, in send
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/HassBridge.indigoPlugin/Contents/Server Plugin/libs/requests/adapters.py", line 514, in send
SSLError: HTTPSConnectionPool(host='192.168.2.113', port=8123): Max retries exceeded with url: /api/states (Caused by SSLError(SSLError("bad handshake: Error([('SSL routines', 'ssl3_get_record', 'wrong version number')],)",),))
Screen Shot 2020-05-11 at 9.23.57 PM.png (172.05 KiB) Viewed 2304 times
Mon May 11, 2020 7:42 pm
[color=#FF0000]HassBridge Error Exception trapped:HTTPSConnectionPool(host='192.168.2.113', port=8123): Max retries exceeded with url: /api/states (Caused by SSLError(SSLError("bad handshake: Error([('SSL routines', 'ssl3_get_record', 'wrong version number')],)",),))
What Mac OS version is your Indigo server?
Mon May 11, 2020 7:47 pm
farberm offline
Catalina 10.15.4
Indigo 7.4
Mon May 11, 2020 7:48 pm
farberm wrote:
Catalina 10.15.4
Indigo 7.4
OK, then it's not that problem.
Mon May 11, 2020 8:04 pm
Gangotti offline
I am seeing the same thing as farberm.
Z-Wave received "Master Bedroom Ultraviolet" sensor update to 0
HassBridge Debug Getting list of Bridgable Devices
HassBridge Debug Refreshing mappings of Indigo devices to HA devices.
HassBridge Error Exception trapped:HTTPSConnectionPool(host='172.16.1.128', port=8123): Max retries exceeded with url: /api/states (Caused by SSLError(SSLError(1, u'[SSL: UNKNOWN_PROTOCOL] unknown protocol (_ssl.c:590)'),))
SSLError: HTTPSConnectionPool(host='172.16.1.128', port=8123): Max retries exceeded with url: /api/states (Caused by SSLError(SSLError(1, u'[SSL: UNKNOWN_PROTOCOL] unknown protocol (_ssl.c:590)'),))
I am running Indigo 7.4 on OSX 10.12.5
Mon May 11, 2020 8:10 pm
farberm offline
I just got that to disappear by creating a yaml file and restarting indigo. I currently have the yaml file blank. I need to work device and variable definitions I think?? I have SSL certificates and Unvalidted SSL all unchecked.
This is my current error.
HassBridge Error Exception trapped:argument of type 'NoneType' is not iterable
HassBridge Error Error in plugin execution startup:
File "plugin.py", line 190, in startup
File "plugin.py", line 346, in _setup_ha_devices
File "plugin.py", line 362, in _remap_ha_devices
File "plugin.py", line 501, in generate
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/HassBridge.indigoPlugin/Contents/Server Plugin/insteon/type_generators.py", line 70, in generate
TypeError: argument of type 'NoneType' is not iterable
Mon May 11, 2020 8:24 pm
WonderSlug offline
I dont think yours is the same as farberm's. The error message is different. Yours still kinda points to the Home Assistant you are hitting not setup for SSL. Can you check and make sure the URL you hit Home Assistant with is https and not http. If its http then you dont have SSL setup on your Home Assistant.
A screenshot of your config would also help.
Mon May 11, 2020 8:26 pm
WonderSlug offline
Ok this is probably a bug. Let me try it with an empty yaml file. Does it work without the "use customization file" turned on?
Mon May 11, 2020 8:39 pm
WonderSlug offline
Did a quick release with a fix for the empty customization file.
v1.0.2
WonderSlug offline
v1.0.2 Released
- Fix for empty customization file
Tue May 12, 2020 1:31 am
farberm offline
I am still getting this error even with the yaml, file,filled in correctly with device and variables . is there any specifics on the yaml file name. I called mine hassbridge.yaml. l also get the error if customization file unchecked.
Starting plugin "HassBridge 1.0.2" (pid 48333)
Started plugin "HassBridge 1.0.2"
HassBridge Error Exception trapped:'NoneType' object has no attribute 'name'
File "plugin.py", line 399, in _remap_ha_devices
File "plugin.py", line 523, in generate
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/HassBridge.indigoPlugin/Contents/Server Plugin/variables/type_generators.py", line 45, in generate
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/HassBridge.indigoPlugin/Contents/Server Plugin/variables/devices.py", line 139, in __init__
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/HassBridge.indigoPlugin/Contents/Server Plugin/variables/devices.py", line 33, in __init__
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/HassBridge.indigoPlugin/Contents/Server Plugin/hass_devices/base.py", line 301, in __init__
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/HassBridge.indigoPlugin/Contents/Server Plugin/hass_devices/base.py", line 218, in __init__
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/HassBridge.indigoPlugin/Contents/Server Plugin/hass_devices/base.py", line 99, in __init__
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/HassBridge.indigoPlugin/Contents/Server Plugin/hass_devices/base.py", line 45, in __init__
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/HassBridge.indigoPlugin/Contents/Server Plugin/hass_devices/base.py", line 81, in name
AttributeError: 'NoneType' object has no attribute 'name'
Tue May 12, 2020 7:13 am
WonderSlug offline
I dont think this is an issue with the filename. This error is different and not part of the customization file stuff. You can name the file anything.
This is odd because it is erroring as if there is an indigo device without a name. Do you have one that is not named? I should be handing that error none the less. But it is interesting.
Tue May 12, 2020 7:20 am
WonderSlug offline
Actually I was wrong. I was able to recreate it on a variable. Its a bug I will get a fix out for.
Tue May 12, 2020 9:02 am
WonderSlug offline
v1.0.3 has been Released
  • Fixed bug blocking variables from being registered
  • Fixed bug where variable indigo entity not accounted for in naming.
Tue May 12, 2020 9:04 am
WonderSlug offline
v1.0.3 should has the fix for this
