Gangotti wrote:I am seeing all of my zwave devices in MQTT, however, my multi-sensors are only showing the status of the motion and tamper but none fo the temperature, humidity, luminance, and UV values. I am assuming that this is because the plugin only pulls the values with on/off characteristics and not the "analog" values?
Gangotti wrote:I also want to point out the problem I was having was with the z wave lock and its battery status, when I unclicked the create battery sensors, the problem went away.
dproctor wrote:WonderSlug,
When I use HA to turn on or off any of my lights (dimmers) the command is sent twice in indigo. Any idea why that would be? Not a big deal, just curious as to why. This doesn't happen when controlling any of my relay switches.
Gangotti wrote:sensors are working great, let me know if you need a tester for the locks!
WonderSlug wrote:dproctor wrote:WonderSlug,
Fix is in v1.2.0. Thanks
dproctor wrote:I have now noticed another small issue. It seems that with regard to the Virtual Devices, HA only sees the first one as a Device and then all the others become related entities to that first Device instead of Devices of their own. I am still able to control them even as entities, I just can't put those that are just entities into areas of HA.
WonderSlug wrote:dproctor wrote:I have now noticed another small issue. It seems that with regard to the Virtual Devices, HA only sees the first one as a Device and then all the others become related entities to that first Device instead of Devices of their own. I am still able to control them even as entities, I just can't put those that are just entities into areas of HA.
Ok thanks.. Being tracked here: https://github.com/wonderslug/hassbridge/issues/7
WonderSlug wrote:WonderSlug wrote:dproctor wrote:I have now noticed another small issue. It seems that with regard to the Virtual Devices, HA only sees the first one as a Device and then all the others become related entities to that first Device instead of Devices of their own. I am still able to control them even as entities, I just can't put those that are just entities into areas of HA.
Fixed in v1.2.1
dproctor wrote:It appears to still be exhibiting the same behavior. Of the 3 Virtual devices (all Device Groups) that I have, only the first one (alphabetically) becomes a device in HA and the other 2 only become related entities to the first one instead of devices of their own. My knowledge is quite limited so sorry I'm not much help troubleshooting. However, I have noticed that now, the one virtual device I have that in Indigo is made up of a dimmer and a switch shows up as a binary sensor vice a switch in HA. If I change the virtual device so it only has one type, ie. only dimmers or only switches, they show up correctly as a switch in HA.
