That fixed everything. No issue. I can now see the items in MQTT explorer and on my Hass setup.
Thanks for the prompt fix.
Gangotti wrote:The good news is I have some of my devices that are showing up in MQTT,. This means we are configured and sending device data. The devices that are showing up in HAssio are able to be controlled!! However, out of the 83 Insteon DEvices, I am only seeing 33 DEvices in MQTT, this is the same with Zwave devices and virtual devices. As a matter of fact, I am only seeing 40 of 136 that are in the plugin configuration window. Is it and indigo device naming issue, or is it limited to only 40 devices?
additionally, I am seeing this error code in the indigo log.
HassBridge Error Error in plugin execution UiClosed1:
File "plugin.py", line 149, in closedPrefsConfigUi
File "plugin.py", line 132, in update_perfs
File "plugin.py", line 481, in _register_ha_devices
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/HassBridge.indigoPlugin/Contents/Server Plugin/hass_devices/base.py", line 408, in register
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/HassBridge.indigoPlugin/Contents/Server Plugin/hass_devices/sensor.py", line 61, in _send_state
AttributeError: 'RelayDevice' object has no attribute 'sensorValue'
Gangotti wrote:I do have the debugging turned on. this is the device that is causing the error
HassBridge Debug Sending config for Bar Patio Door Lock Battery:111322071_battery to topic homeassistant/sensor/bar_patio_door_lock_battery/config
HassBridge Debug Sending availability of online for Bar Patio Door Lock Battery to homeassistant/sensor/bar_patio_door_lock_battery/status
The door lock is a z wave device.
WonderSlug wrote:Gangotti wrote:I do have the debugging turned on. this is the device that is causing the error
I dont have any explicit support for locks in HassBridge right now. It appears that they show up in Indigo as a Relay type with a specific subtype. Support for locks could be something I can try to add later if you would be willing to be a guinea pig and work with me on it. I have an August lock that has z-wave capability but I usually dont use it that way. Ill see what I can flesh out with it.
At this point I would not include that in the selected bridge devices.
I did a quick release (v1.0.4) that has some more verbose.registration debug logging (yes it can get more verbose) which might help as well.
dproctor wrote:For what it's worth, I have 3 zwave locks and they appear to work for me. However, none of my virtual devices are not showing up at all. In the HassBridge configuration menu under Devices to Bridge the virtual devices don't show up as devices to select and I've tried checking Bridge all possible devices but that doesn't add the virtual devices either.
WonderSlug wrote:dproctor wrote:For what it's worth, I have 3 zwave locks and they appear to work for me. However, none of my virtual devices are not showing up at all. In the HassBridge configuration menu under Devices to Bridge the virtual devices don't show up as devices to select and I've tried checking Bridge all possible devices but that doesn't add the virtual devices either.
If it doesnt show up in the list of possible devices then its not going to be bridged when all possible is selected .... cause they might not be possible right now
What type of virtual devices are you working with?
Right now it really only works with Device Groups and is not setup to work with Virtual on/off or Sprinkler groups.
dproctor wrote:Ahh ok, mine are set up as Virtual on/off devices.
farberm wrote:Wonderslug:
Thanks for the update. I will check it out the next day or so...
One additional question...
My MQTT explorer shows both a homeassistant and indigohassbridge topics that are the same. Any reason for this? I was expecting only one topic...
Here is my config file and image
Gangotti wrote:WonderSlug, I just updated to 1.1.0 and all the errors have disappeared and I Have all my Insteon devices. Excellent work with the plugin. If you should ever need a Guinea Pig, I would be happy to help.
WonderSlug wrote:dproctor wrote:Ahh ok, mine are set up as Virtual on/off devices.
Ok well it was hard (2 lines of code) but I added support for Virtual on/off devices. its in v1.1.0. Let me know if this is working for you and how you expect.
