Compatability
Fri Aug 19, 2022 12:16 pm
farberm offline
Compatability
Is there a planned update for compatibility?
Sun Sep 04, 2022 12:54 pm
emergent offline
Re: Compatability
I hope so. This plugin stops working with the next release of Home Assistant.
Sun Sep 04, 2022 3:28 pm
Re: Compatability
Considering the author hasn't posted on the forums in 11 months, I wouldn't hold your breath.
Fri Sep 09, 2022 12:51 pm
Venicenerd offline
Re: Compatability
Is there an alternative we can use to get our devices into Home Assistant?
Also, why will the plug-in stop working with the next version of home assistant?
Mon Oct 10, 2022 12:17 pm
Venicenerd offline
Re: Compatability
Hey guys I just want to clarify. Will this plugin still work with 2022.1? I need to figure out a way to bridge my Insteon devices to HomeAssistant and the first post makes it seem as if this plugin will no longer work?
Mon Oct 10, 2022 2:25 pm
Re: Compatability
It should work with 2022.1, but not the next release without an update from the developer.
Fri Dec 09, 2022 5:49 pm
Venicenerd offline
Re: Compatability
@emergent why does it stop working with the next version of Home Assistant? I thought the next Indigo update was going to be the issue?
Sun Jul 16, 2023 7:34 am
farberm offline
Re: Compatability
Did you ever find an update for this to work?
