Plugin Error
Thu Jul 30, 2020 10:26 pm
bigballer2k offline
Plugin Error
Every time I try to start the plugin, I get the following error which prevents it from starting and allowing me access to the configuration screen. I've tried disabling the plugin as well as deleting and re-installing but have not yet figured out how to get it to work.
Reloading plugin "HassBridge 1.2.2"
Starting plugin "HassBridge 1.2.2" (pid 13041)
HassBridge Error Error in plugin execution InitializeMain:
File "<string>", line 1, in <module>
File "plugin.py", line 93, in __init__
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/HassBridge.indigoPlugin/Contents/Server Plugin/__init__.py", line 53, in __init__
ValueError: invalid literal for int() with base 10: ''
Stopping plugin "HassBridge 1.2.2" (pid 13041)
Stopped plugin "HassBridge 1.2.2"
Fri Jul 31, 2020 8:17 am
WonderSlug online
Re: Plugin Error
Howdy,
Try looking at your config at the MQTT server port. Make sure it doesn't have a space or something odd in it. That line the error is happening will fail if there is non number characters in there.
I will look at adding some better config validation as well.
