File path to save CSV
Sat May 02, 2020 2:44 pm
Hi Neil.
I noticed this afternoon that the plugin throws it's toys out of the pram if I ihaven't set a file path in the plugin config, but I have checked the box to save CSV in a device.
(Disclaimer: I did this on purpose to see if it broke!)
It's probably worth defaulting the CSV path to either your plugin folder or to ~/Documents/Octopus rather than to "" so that the CSV has somewhere to save to.
This is three lines of code I have in the Sense plugin which also has the option to save CSVs:
self.csvPath = "{}/Preferences/Plugins/{}".format(indigo.server.getInstallFolderPath(), self.pluginId)
self.csvActive = "{}/Preferences/Plugins/{}/activeLog.csv".format(indigo.server.getInstallFolderPath(), self.pluginId)
self.csvDaily = "{}/Preferences/Plugins/{}/dailyLog.csv".format(indigo.server.getInstallFolderPath(), self.pluginId)
Ironically it's probably the only place in my plugins I've used .format() yet! Still getting my head around those and the new loggers!
Peeter
Sun May 03, 2020 3:43 am
neilk offline
Re: File path to save CSV
Peter,
Thanks and a good catch. Initially I was planning a single device and making the CSV a plugin level so the field was hidden unless checked. To be fair I hadn’t built any validation but when I moved to device level selection I should have thought of this. Thanks for the suggestion and the testing, I will fix.
Neil
Sun May 03, 2020 4:31 am
I found this reference of great help when I was learning the various .format() parameters: PyFormat: Using % and .format() for great good!
You're on your own with the new loggers. 8)
Sun May 03, 2020 5:47 am
Hehe, I have that link as a favourite/bookmark... does that help?
Sun May 03, 2020 5:59 am
It does.
Just like having the bits to repair the gap between the driveway and the garage sitting on my workbench is akin to them being installed.
Or how having a salad with dinner counteracts the bowl of ice cream afterwards.
Sun May 03, 2020 7:43 am
neilk offline
Peter,
The sad thing was I had tested for the empty path, but then went ahead and wrote to it anyway. Doh. Anyway new version posted that implements your suggestion, and now also tests that a user supplied directory is actually writable. A couple of other things tidied.
Now moving on to Jon's suggestions to make the API calls once a day (or only when necessary) and to maintain a local results copy. I will also tidy up the counter intuitive use of UTC versus UK Local for the daily max, min and average. This will also help with adding consumption data in as well.
Thanks for the tip and the collaboration.
Neil
