Online Sensor plugin
Mon Jun 08, 2020 3:17 pm
dkillmer offline
Re: Online Sensor plugin
I decided to bag the plugin and write a simple script.
import speedtest
st = speedtest.Speedtest()
indigo.variable.updateValue("DownloadSpeed", str("{:.2f}".format(st.download()/1000000)))
indigo.variable.updateValue("UploadSpeed", str("{:.2f}".format(st.upload()/1000000)))
Tue Jun 09, 2020 12:59 pm
kmarkley offline
When the plugin was built, speedtest.py automatically tried to share the results and threw an exception if unable to. It looks like the current version makes this optional. I'll need to make a few changes to the plugin to work with the new library, but should be able to do so later this week.
Mon Aug 03, 2020 2:41 pm
jstewart30 offline
I'm having the same error about not being able to submit results to speedtest. Running 10.13 if that helps at all. Just wanted to see if you are able to implement the above change and/or if there's any other insight as to why the error is occurring. Thanks in advance!
Thu Apr 08, 2021 3:53 am
racarter offline
Hi
The last couple of days I've been getting errors in the event log. I switched on debug messages and I'm getting this:
8 Apr 2021 at 10:38:17
Online Sensor Debug updating states on device "Internet Connection":
Online Sensor Debug onOffState: True
8 Apr 2021 at 10:39:54
Online Sensor Debug performSpeedtest: Internet Speed
Online Sensor Error invalid literal for int() with base 10: ''
Online Sensor Debug performSpeedtest: 0.226945161819 seconds
Online Sensor Debug updating states on device "Internet Speed":
Online Sensor Debug onOffState: False
I'm guessing Speedtest is returning something bad.
I've found a solution:
https://github.com/sivel/speedtest-cli/pull/769
Fri Apr 09, 2021 6:46 pm
ryanbuckner offline
Getting the following error every few minutes:
Sat Apr 10, 2021 11:59 am
kmarkley offline
New version 0.0.15 on the plugin store updates the speedtest.py library which should fix this issue. Also (finally) makes sharing speedtest results optional.
Sun Apr 11, 2021 3:36 pm
ryanbuckner offline
Thanks! Just installed. I'll let you know what I see
Fri Mar 18, 2022 12:07 pm
Liptrot offline
The Online Sensor plug-in Speedtest device has started giving HTTP 503 errors .
Is there any way to work around this ?
Thanks !!!!
Sat May 14, 2022 8:37 pm
DVDDave offline
Thanks !!!!
Same problem here
Fri Jun 03, 2022 5:37 pm
TimH offline
I just starting using this plugin - some nice features, but `i too am seeing the 503 errors. I did some debugging and it appears the plug-in is failing when it attempts to share the results with speedtest.net. (although I have share unchecked? - likely some left over code) It looks like when its updating its status in plugin.py (when the tests are complete) at this line : {'key':'share_link', 'value':'r.share()' }, Its getting the 503 server busy error (sometimes). As a temp fix, I updated that line to : {'key':'share_link', 'value':'No Thanks' },. And it appears to be working well now. I hope this helps until the author can take a look and make a permanent fix. And, thanks again to the author for a handy plugin!
Fri Jun 10, 2022 8:16 am
kmarkley offline
I searched my logs and found a couple of these errors, but I'm not seeing them on a regular basis. The plugin needs updating to python 3 and the newest version of the speedtest library. Hopefully that will address this as well. Unfortunately it will probably be a month or two before I can get to it.
Wed Aug 10, 2022 3:32 pm
farberm offline
Happy to wait, I use this plugin all the time.
Wed Oct 05, 2022 7:15 pm
Dual offline
I use this plugin to test if my internet is working by pinging a variety of addresses. If they all fail then I have Indigo restart my modem and router. Will this plugin be updated to work with future versions of Indigo?
Fri Mar 03, 2023 12:16 pm
I'm taking another look at my "yellow" plugins and this is one.
Any thoughts about whether this will be updated for >2022.2?
Of all the non-compliant plugins I use, this is probably easiest to replace with some sort of python script, but this plugin is very convenient.
Tue May 09, 2023 7:26 pm
Grognard offline
It's starting to look like this plugin is not going to be updated to Python 3 any time soon. Any other users out there who have replaced this with a script?
