Botvac Connected with Neato Plugin
Thu Apr 09, 2020 7:05 pm
kmarkley offline
Re: Botvac Connected with Neato Plugin
Glad to hear it. Update pushed to the plugin store.
Sat Apr 25, 2020 7:20 am
shapa offline
Two D7s, works fine with plugin.
Thanks a lot!
Fri May 08, 2020 8:37 am
shapa offline
Noticed that the plugin is stopped to work.
Had to restart it manually. Looks like it is hanging for some reason. Enabled debug, will continue to monitor.
(" Error process (pid 8866) failed to quit after polite request -- forcing it to quit now")
Fri May 08, 2020 3:39 pm
kmarkley offline
I've had occasional issues with the plugin failing to tell if it has a valid connection to neato's servers (as mentioned in the plugin description). The third-party library I'm using to access the API doesn't seem to expose the source of the problem so I haven't figured out how to identify or rectify the situation automatically. When this happens I usually have to edit and re-save the robot's indigo device.
I have not seen an issue with the plugin hanging and failing to quit after a polite request. It almost sounds like a network issue but I can't be sure. Please let me know if you find any more clues.
Sun Jun 07, 2020 6:00 pm
vvrangler offline
I am receiving the same error message, but it looks like I am running a different firmware version, 4.5.3-189, do you think that is the problem, different versions reporting different json data?
Jun 7, 2020 at 4:54:45 PM
Neato Botvac "Upstairs" request status
Neato Botvac Error "Upstairs" received malformed status message
Neato Botvac Debug {
"action": 0,
"alert": null,
"availableCommands": {
"goToBase": false,
"pause": false,
"resume": false,
"start": true,
"stop": false
"availableServices": {
"IECTest": "advanced-1",
"findMe": "basic-1",
"generalInfo": "basic-1",
"houseCleaning": "basic-4",
"logCopy": "basic-1",
"manualCleaning": "basic-1",
"maps": "basic-2",
"preferences": "basic-2",
"schedule": "basic-2",
"softwareUpdate": "basic-1",
"spotCleaning": "basic-3",
"wifi": "basic-1"
"cleaning": {
"category": 4,
"mapId": "",
"mode": 1,
"modifier": 1,
"navigationMode": 1,
"spotHeight": 0,
"spotWidth": 0
"data": {},
"details": {
"charge": 99,
"dockHasBeenSeen": false,
"isCharging": false,
"isDocked": true,
"isScheduleEnabled": false
"error": null,
"meta": {
"firmware": "4.5.3-189",
"modelName": "BotVacD7Connected"
"reqId": "1",
"result": "ok",
"state": 1,
"version": 1
Neato Botvac Debug "Upstairs" status update complete
Tue Jun 09, 2020 1:15 pm
kmarkley offline
The issue seems to be that your robot is in cleaning category 4.
The plugin is only aware of 3 cleaning categories -- manual (1), house (2), and spot (3). Please put your robot in one of these categories and confirm the plugin can then successfully complete the status request.
If so, let me know what this new category is and I'll add it to the plugin.
Wed Jun 17, 2020 4:34 pm
vvrangler offline
@kmarkley
So this only seems to happen when I am in House mode, however I do have a stored floorplan that it cleans from and I either have to select a room or entire house.
I have included examples of the error for both below. So my assumption would be that Category 4 must mean floorplan?
On this attempt I selected a single room "Family Room" from the floorplan
"action": 4,
"alert": null,
"goToBase": false,
"pause": true,
"resume": false,
"start": false,
"stop": false
"maps": "basic-2",
"wifi": "basic-1"
"cleaning": {
"boundary": {
"id": "877ab40a-f7cf-4105-8dbb-7fca9d7e5788",
"name": "Family Room"
"category": 4,
"mapId": "2019-12-02T01:01:09Z",
"mode": 1,
"modifier": 1,
"navigationMode": 2,
"spotHeight": 0,
"spotWidth": 0
"data": {},
"details": {
"charge": 94,
"dockHasBeenSeen": true,
"isDocked": false,
"error": null,
"meta": {
"reqId": "1",
"result": "ok",
"state": 2,
"version": 1
In this one I selected Entire House
"action": 0,
"alert": null,
"goToBase": false,
"pause": false,
"resume": false,
"start": true,
"stop": false
"maps": "basic-2",
"wifi": "basic-1"
"cleaning": {
"category": 4,
"mapId": "",
"mode": 1,
"modifier": 1,
"spotHeight": 0,
"spotWidth": 0
"data": {},
"details": {
"charge": 96,
"isCharging": true,
"isDocked": true,
"error": null,
"meta": {
"reqId": "1",
"result": "ok",
"state": 1,
"version": 1
During the Spot and Manual there were no errors reported.
Thanks again for your help!
Sat Jun 27, 2020 12:38 pm
McJohn offline
Thank you so much for all your effort for the Botvac Connected with Neato Plugin!
It's plug and play! Super! (We've been waiting for years)
Everything is working fast and smooth.
One question:
The Botvac Connected does not want to go to his basket:
Neato Botvac Error "Neato" go to base command not currently available
It's this one:
https://www.neatorobotics.com/support/b ... formation/
How could we fix this?
Thanks for your support.
Regards,
John
