siclark wrote:Hi, I have installed the lastest version but still no joy. I see the schedule names in the MQTT settings payload but still no name in the drop down.
siclark wrote:Morning. I have just tried that, although had rebooted the TRV and made setting changes and verified that this had also republished the settings but no, still not populated.
EDIT: I just realised that my MQTT connector plugin was frozen from lunchtime yesterday and so whilst the log appeared to show MQTT activity, it was only your plugin attempting to send. Nothing coming back into Indigo. A restart of that plugin and all was good, it saw the queue of messages with the settings in, processed them, and I do now see the names in the drop down.
CliveS wrote:Moved message as requested
I noticed that the status icon for my Shelly TRV is an On/Off switch icon (permanently off) instead of a flame icon and the Heat Setpoint icon is a flame but is permanently on. Also no log output when the setpoint is updated.
https://192.168.0.xxx/ext_t?temp=${ev.tC}
siclark wrote:I currently have a Shelly plus H@T linked to my TRv which is nice, but expensive.
Given I’m currently using sonoff zigbee sensors with my TRVs, I’m assuming I could just get those to push temperature updates to the TRV. It doesn’t have to be a Shelly device?
This would make replacing the Spirits with Shelly TRVs cheaper.
I believe the temperature is published here.
- Code: Select all
If I set up a trigger for changes on temp on any device I could presumably do the same with an action. (Not sure what action or plug-in though)
aaronlionsheep wrote:That's perfect Clive, let me see what I can come up with. This is my first interaction with Thermostats in Indigo, and I've had to do a lot of YouTube watching to learn about what a TRV is. I've been flying blind for a bit
If you have you setpoint at 18C and your TRV finally detects the temperature has reached 18C, does it fully close the valve, or does it keep it slightly open to keep the temperature constant? I'm wondering if I should monitor the value position going to 0 as an indicator the TRV is "off", or if I should be comparing the current temperature with the target temperature.
aaronlionsheep wrote:siclark wrote:I currently have a Shelly plus H@T linked to my TRv which is nice, but expensive.
- Code: Select all
Ok, so that must be what one of the MQTT topics if for
What if the TRV config allowed you to pick a device or variable in the device config to use as an external temperature sensor. It could be any Indigo sensor device (even non-Shelly) that reports a temperature, or a variable that contains a temperature. When this device/variable changes, the plugin could relay that temperature to the TRV as the external temperature.
siclark wrote:The heating is on whilst the valve is open. Comparing setpoint to reported is not reliable as yes it tries to keep the valve a little open to maintain the temp.
siclark wrote:That would be perfect (and just as the TRV plug-in does!) I’m even wondering if I have 2 in a room and create a device of the average to use in some cases.
