Shelly Dimmer 2
Tue Mar 22, 2022 3:15 pm
Colly offline
Shelly Dimmer 2
Hi Aaron,
Recently purchased a Dimmer 2 and just trying it out. Getting the following in the log.
   Error                           device "Dimmer Sit Room" state key curEnergyLevel not defined (ignoring update request)
   Error                           device "Dimmer Sit Room" state key accumEnergyTotal not defined (ignoring update request)
Seems to be working happily all the same.
Screenshot from MQTT Explorer for additional info.
Colly
Screenshot 2022-03-22 at 21.14.23.png (42.58 KiB) Viewed 2613 times
Tue Mar 22, 2022 3:43 pm
aaronlionsheep offline
Re: Shelly Dimmer 2
Colly wrote:
Hi Aaron,
Colly
Hi Colly,
I'm not sure how that got missed, but I don't have the energy states defined in the Indigo device for the dimmer. So when the energy values are processed and written to the energy states, the error is produced.
I will have to add this to my bug list for the next release. I did finally get a "next gen" device, so I am still working on the new API.
Aaron
Tue Mar 22, 2022 3:54 pm
Colly offline
Re: Shelly Dimmer 2
Aaron,
No problem at all
Just wiring up my i4 on the test bench so ready when you are. :)
Colly
Sat Apr 30, 2022 8:49 am
Re: Shelly Dimmer 2
Are you still having issues with this? I have been unable to reproduce this with the output you have shown from MQTT Explorer.
Sat Apr 30, 2022 2:27 pm
Colly offline
Re: Shelly Dimmer 2
Yes, still happening. See log entry in last few mins.Image
Sat Apr 30, 2022 2:39 pm
Re: Shelly Dimmer 2
Try editing and saving the device. Sometimes that fixes state key issues.
Sat Apr 30, 2022 2:45 pm
Colly offline
Re: Shelly Dimmer 2
No joy unfortunately.
Sat Apr 30, 2022 2:54 pm
Re: Shelly Dimmer 2
Can you confirm if you are running the latest version of the plugin (0.7.1)?
Sat Apr 30, 2022 2:57 pm
Colly offline
Re: Shelly Dimmer 2
Yes running 0.7.1
Sat Apr 30, 2022 3:18 pm
Re: Shelly Dimmer 2
Colly wrote:
Yes running 0.7.1
Ah I figured it out. I'm still running Indigo 7.4.1 on a 2007 Mac mini :shock: . It looks like the property "SupportsEnergyMeterCurPower" was renamed to "SupportsPowerMeter" and I didn't notice.
The latest code (https://github.com/AaronLionsheep/Shell ... /0.7.2.zip) should have this new property included. Please give that a try and let me know if that solves everything. You will probably have to open the device configuration and save it to apply the property to the device.
Sat Apr 30, 2022 3:20 pm
Colly offline
Re: Shelly Dimmer 2
:wink: I'll give that a try and let you know how I get on.
Sat Apr 30, 2022 3:36 pm
Colly offline
Re: Shelly Dimmer 2
Unfortunately still not resolved:
Although I do see a change from previous, the entry below is not appearing at the moment:
Sat Apr 30, 2022 3:45 pm
Re: Shelly Dimmer 2
Did you also open the device config and resave? That was the only change I was able to find.
Sat Apr 30, 2022 3:50 pm
Colly offline
Re: Shelly Dimmer 2
Yes opened and changed a parameter and resaved. Also reloaded the plugin after that.
Tue Aug 16, 2022 2:37 pm
Colly offline
Re: Shelly Dimmer 2
Hi Aaron,
Any chance you could take a look at this error in a future update? Bit of a nuisance in the log. Get it every 30 secs or so :roll:
16 Aug 2022 at 21:35:51
Colly
