Shelly 2.5 as Shutter
Fri Mar 04, 2022 11:13 am
MarcoGT offline
Hi all,
is anyone using the Shelly 2.5 as roller shutter?
I have only on/off but no "dimming" options.
Marco
Fri Mar 04, 2022 3:33 pm
aaronlionsheep offline
Re: Shelly 2.5 as Shutter
MarcoGT wrote:
Hi all,
Marco
Hi Marco,
The Shelly 2.5 has two modes, relay and roller. I initially added the relay mode to expose the 2 relays individually. There was never interest in having the roller (shutter) mode supported, so it is not possible at the moment.
If you are trying to use your Shelly 2.5 as a shutter controller in roller mode then I can work on adding support for that mode.
Aaron
Sat Mar 05, 2022 12:28 am
MarcoGT offline
Hi Aaron,
yes, it would be nice if supported could be added.
Thank you
Marco
Sat Mar 05, 2022 7:25 am
I have added that one to Shellydirect. And I tried to actually install it physically. But After some hours I have up.
Die would first try if you can make it work with your Gardine with the phone.
Karl.
Sat Mar 05, 2022 8:33 am
MarcoGT offline
At the moment I cannot connect it physically, sorry :(
As far as I understood at the moment there are no Z-Wave modules which work with Indigo
- Aeotec --> not fully supported
- Fibaro FGR-223 --> not fully supported
- Fibaro FGR-222 --> not on the market anymore
Maybe Qubino?
The Shelly is very nice because is very small compared to the other ones
Sun Mar 06, 2022 8:57 am
tazswe offline
Qubino Flush Shutter works and the Shelly works with a phone or Karls Shelly plugin.
Sun Mar 06, 2022 10:07 am
MarcoGT offline
I read about quality problem of Qubino.
Karl wrote above that the 2.5 is not working as roller controller
Did you try it?
Sun Mar 06, 2022 10:15 am
tazswe offline
Pls note that there are two plugins for Shelly.
The shutters work with this plugin by Karl.
https://www.indigodomo.com/pluginstore/224/
However if Aaron makes the Shellymqtt plugin work in shutter mode it should be easier for you,
Sent from my iPad with Tapatalk
Sun Mar 06, 2022 11:10 am
MarcoGT offline
Yes, I think this is shellydirect, but if you have a look few message above, Karl wrote
Karl.
Therefore I think it does now work
Or does it work in your setup?
Sun Mar 06, 2022 11:13 am
tazswe offline
It was working in my setup when I tried it.
Sun Mar 06, 2022 11:23 am
MarcoGT offline
Ok, thanks, then I will give it a try!
