Error found on V0.7.1
Thu Apr 15, 2021 11:20 am
CliveS offline
Aaron,
Just went to upgrade to the latest Shelly firmware and when using Firmware Update Helper, I pressed the 'Reload' button.
15 Apr 2021 at 18:01:39
   ShellyMQTT Error                Error in plugin execution UiAction:
TypeError: menuChanged() takes exactly 4 arguments (3 given)
All devices updated fine so not sure what the Reload actually does.
Also can you add an Update All button as going back to do each update when Shelly release a mass update (like today) would be handy.
CliveS
Indigo 2021.1.1 : macOS Big Sur 11.6.5 : MacBook Retina 2014 : 2 .6 GHz Dual Core i5. : 8 GB. : Samsung 970 1TB EVO SSD
Thu Apr 15, 2021 2:20 pm
aaronlionsheep offline
Re: Error found on V0.7.1
Thanks for bringing this up.
The reload button is just to update the UI after pressing the Discover shellies button. This is usually not needed as the devices are pretty good about self-reporting information. I will be sure to update this as I see where I mistakenly made the change which broke it.
Yeah I can see where this would be useful, so I will add this to the list as well!
