In need of mqtt help
Sat Jan 30, 2021 5:41 am
tazswe offline
Re: In need of mqtt help
This is the event log from my Mosquitto serverImage
Skickat från min iPad med Tapatalk
Sat Jan 30, 2021 5:45 am
tazswe offline
The mqtt trigger with I hope is correct settings.
No conditions and no actions. Shouldn’t there be an action?
Sat Jan 30, 2021 5:50 am
tazswe offline
Created 3 devices for the I3, one for each channel
Sat Jan 30, 2021 5:59 am
tazswe offline
I have created a trigger for the I3 like this with no conditions and just a simple action with a sound and a pushover notification.
Sat Jan 30, 2021 6:03 am
tazswe offline
Finally I have restarted the server, Indigo and all plugins.
I have also temporary turned of the firewall while testing.
Made fresh instalments of everything.
What am I missing?
Sat Jan 30, 2021 6:05 am
Colly offline
I will try to help out if I can, I’m by no means an expert but have managed to get mine working. I’ll grab a coffee and look at your setup on my Mac.
Sat Jan 30, 2021 6:19 am
tazswe offline
Grateful if you would like to compare your settings with mine.
Sat Jan 30, 2021 6:22 am
Colly offline
In your trigger you should have Message Type filled in with "shelly". Try this change.
Sat Jan 30, 2021 6:42 am
Colly offline
This summary is as much for my benefit as yours as I'm putting it in writing as to how I understand the process to be. If I've got it wrong then Aaron or Joe can correct me.
Create a connection to your Mosquitto server.
Use MQTT Connector for this. Input IP address to replicate the Shelly setting on the actual device you’re trying to connect to, e.g. 192.168.1.15:1883
Next create a trigger to act on the broker activity.
The trigger should connect to the broker mentioned above. Add, in this order,
• Select Match Type - Match. Match String as “shellies”
• Select Match Type “Any (wildcard)”
Select Queue message
Enter Message Type as “shelly” (this can be anything you choose but must be used in device that will be created next.)
Create new Shelly MQTT device, let’s go with the Shelly 1PM. The setup you have from one of your earlier messages looks correct. The key here is that the Message Type matches the Message Type from your trigger.
Now it might be worth selecting the option from Shelly MQTT plugin to discover Single Shelly - not sure how critical it is however it won't do any harm.
EDIT: Changed incorrect reference to adding Match "Any".
Sat Jan 30, 2021 6:58 am
tazswe offline
I have added shelly and restarted everything.
Still not working.
Sat Jan 30, 2021 7:10 am
Colly offline
Let's go back to the beginning again.
For your MQTT Connector do you see values being updated as per screenshot? This should continually update if working.
Once that is working then we should hopefully be able to progress all the way through. It can be frustrating as I've had plenty of head scratching moments in the past - we'll get there. :D
Screenshot 2021-01-30 at 13.07.31.png (21.4 KiB) Viewed 3126 times
Sat Jan 30, 2021 7:26 am
The "Match: Any" line is wrong. Delete it, then change the "Match Type" pop-up control that currently says "Match" so it says "Any", then add it. You'll end up with two lines:
Match: shellies
Any:
Then you need at add something in the Message Type field. You used "Shelly" in the Shim configuration, so use that here. And there is an action, it's that check box. Read the fine print under it.
Sat Jan 30, 2021 7:33 am
• Match “shellies”
• Match “any”
You never match on the string "Any". The term Any is a "match type", of which there are three: "Match", "Any", and "End". "Match" is for a specific string in the topic, "Any" is for a wildcard position in the topic, and "End" causes the matching logic to stop scanning the topic. The "End" action is only needed in very specific circumstances where you need to match on some partial topic strings and not others.
Sat Jan 30, 2021 7:34 am
tazswe offline
Yes,
The change of any to Any(Wildcard) solved everything.
Thanks a lot Flying diver, Colly and Aaron for all the help.
Sat Jan 30, 2021 7:36 am
Colly offline
Great. I should've spotted the incorrect reference to 'Any' (even though my setup is correct) - knew it would need an expert on the job..
