Releases
Sat Sep 18, 2021 7:39 am
aaronlionsheep offline
Re: Releases
tazswe wrote:
I have ordered a Shelly 1 and a 1pm from the new plus serie. Haven’t found any documentation for the mqtt settings for tem.
Will probably be a week or two before I receive them but will let you know as soon at they arrives.
Sent from my iPad with Tapatalk
If Shelly still don't have the API published, then I would try setting them up as the non-plus models in the plugin. Hopefully the API is the same with these new devices.
Sat Sep 18, 2021 8:21 am
CliveS offline
Re: Releases
Snap, also got a 1 and 1pm plus on order but they are going to be fun to program but I expect Aaron will get stuck in on these.
Aaron, take a look at
[url]
https://shelly-api-docs.shelly.cloud/gen2/
[/url]
CliveS
Tue Sep 28, 2021 8:40 am
tazswe offline
Re: Releases
Received my plus one and plus one pm today.
No way it’s going to work right out of the box, the plugin need some changes.
To make it even more complicated the output is only showed as true or false for a few seconds before it disappears. Not shown on my pic.
Tue Sep 28, 2021 2:19 pm
Re: Releases
That's what I was afraid of. They have completely abandoned the existing API, so these new devices aren't backwards compatible. To get one of these in the US, they are almost a month out if we are to believe their availability estimates.
Don't hold your breath for these new devices to be supported by ShellyMQTT as I don't even have one of these devices yet.
Wed Sep 29, 2021 12:34 pm
CliveS offline
Re: Releases
Aaron, I also have the new Shelly1+ and Shelly1PM+, if you need any info then let me know, I can even get a remote Macbook Air up and running with the Shellies attached that you can have full remote access 24/7 to via Tailscale and NoMachine!, put what software you want on it.
I use that setup extensively when I am away in the motorhome to access Indigo, BlueIris and the NAS and even use it at home on the headerless Raspberry Pi's.
CliveS
Sun Dec 04, 2022 7:55 pm
Re: Releases
Long time no post!
ShellyMQTT v0.8.0 is now available on the plugin store and add support for the Shelly Motion2. I've had this version of the plugin running for a few weeks with 2 of these devices controlling more than half my lights. I haven't touched a switch in weeks, so I figured the code must be pretty stable.
Python 3 support is still coming, but no ETA (sorry). I had to buy a new MacMini and get off Indigo 7.4.1 first :shock:
Sun Feb 26, 2023 7:55 pm
Re: Releases
aaronlionsheep wrote:
Long time no post!
A few new releases are now available :D
  • v0.9.0 - Support for the Shelly TRV was added
  • v1.0.0 - Moved to Indigo API v3.0 (Python 3). Indigo 2022.1 or later is now required.
  • v1.0.1 - Fixed a bug when setting color levels for certain devices.
Mon Feb 27, 2023 2:32 am
CliveS offline
Re: Releases
I noticed that the status icon for my Shelly TRV is an On/Off switch icon (permanently off) instead of a flame icon and the Heat Setpoint icon is a flame but is permanently on. Also no log output when the setpoint is updated.
CliveS
Tue Feb 28, 2023 3:38 pm
Re: Releases
Do you mind if we move this to the TRV thread? viewtopic.php?f=330&t=26820
Mon Oct 09, 2023 12:55 pm
Re: Releases
v1.0.2
  • Preserve previous TRV schedule names
v1.1.0
  • Configurable TRV heating status icon
  • Populate the Indigo firmware column
  • Ignore Gen 2 device announcements
