Find My iDevices! (April 2013+)
Thu May 30, 2013 11:19 am
bschollnick2 offline
Re: Find My iDevices! (April 2013+) does not ask for devices
kw123 wrote:
- moving file into the proper directory (btw the directory given /Plugins/Library/Application Support/Perceptive Automation/Indigo 5/IndigoWebServer/Plugins should not have the first /Plugins before Library?)
- restart server
There are two different plugins to be installed.
There's the Find My iDevices.IndigoPlugin file, which goes into /Library/Application Support/Perceptive Automation/Indigo 6/Plugins.
Then there's the Find-My-Idevices folder, in the IWS Plugin folder, that needs to be put in the /Library/Application Support/Perceptive Automation/Indigo 6/IndigoWebServer/Plugins folder.
kw123 wrote:
==> a) Please ensure that you add the MobileMe account information for the iDevices you wish to monitor. <== does not show up.
From the log clip that you included, it appears that you need to add an Apple ID Login Device, and the Devices for your iDevices.
Steps to Create an Apple ID Login device
Click New Device
Change the Type to Plugin
Change the plugin to ”Find My IDevices”
Change Model to ”Apple ID Login information (For MobileMe & iCloud)”
Fill in your Apple ID username and password
Steps to Create an iDevice Record
Click New Device
Change Model to ”iDevice Registration”
Choose the Apple ID Associated with the iDevice
Choose the iDevice name
Please note: If this is a new device, the iDevice name will not show up, instead it’ll prompt you to close the device. Close the Device record, and exit back to Indigo’s main window. (Make sure to save, and not cancel). This is due to new device’s not having an Indigo device number until the device is initially saved…. FMID needs that Device number.
If necessary, Re-open the iDevice record, and choose the iDevice name.
for v5 - http://bit.ly/T6WBKu
Fri May 31, 2013 4:51 pm
thanks, works fine now, iphone is visible on the map. - and data in the device info.
simple question: how do I get to the location info in e.g. a trigger?
Thx
Fri May 31, 2013 9:18 pm
I am getting every 10 sec now the following error messages in the log file
this happened after I added a trigger to send a mobileme message when iPhone is <0.1 miles and set variable away=false
but continues, after i inactivate the trigger
Find My IDevices Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 966, in runConcurrentThread
File "plugin.py", line 865, in run_search_for_idevices
File "plugin.py", line 712, in fetch_updated_MobileMe_Locations
File "plugin.py", line 795, in process_device
<class 'Boost.Python.ArgumentError'>: Python argument types in
ServerInfo.log(unicode)
did not match C++ signature:
log(CCString message, CCString type='', bool isError=False)
Find My IDevices Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Find My IDevices Debug Running Concurrent Thread
Find My IDevices Retrieving location data
Find My IDevices Debug Logging into Find My iPhone with Apple ID Account (xxxxxxx@me.com)
Find My IDevices Locating - iphone device, (iPhone)
Find My IDevices running with (2, 300) and None
Find My IDevices location: {'latitude': xxxxx, 'timestamp': datetime.datetime(2013, 5, 31, 22, 13, 14), 'longitude': -xxxxx, 'accuracy': 10.0}
Find My IDevices Debug Location - {'latitude': xxxxx, 'timestamp': datetime.datetime(2013, 5, 31, 22, 13, 14), 'longitude': -xxxxx, 'accuracy': 10.0}
Sat Jun 01, 2013 6:41 am
There's something odd with the Trigger, what exactly does the trigger consist of?
The error suggests that the trigger is a map point? If so, what does the map point consist of.
The error itself could be due to bad data or an error in the trigger, I can't tell without additional information.
- Ben
Sat Jun 01, 2013 7:02 am
deleted all triggers and restarted server. have setup one trigger to put notification into log file works sofa.
works now, will wait to see if error comes up again
thanks
Mon Jun 03, 2013 8:42 pm
symo offline
Running version 1.714
After updating to Indigo 6 Beta 8
I'm getting continuos entries in the Event Log:
Find My IDevices Done registering Apple ID
etc...
I had to disable the plugin to get this to stop. Attempting to disable the plugin failed on "polite" request so it was forced to quit.
Thanks for any help.
-Jon
Tue Jun 04, 2013 3:44 am
etc...
Upgrade to v1.715 (https://dl.dropboxusercontent.com/u/241 ... v1.715.zip) which fixes a bug caused by Indigo v6 Beta 8.
- Ben
Tue Jul 09, 2013 10:33 pm
ethank offline
I updated to Indigo 6.0 b10 and running 1.715 of the plugin but it doesn't seem the triggers for "distanceAway" are executing properly. I have it setting a variable to "away" if a phone is more than 0.5 away and it doesn't seem to be executing.
Wed Jul 10, 2013 11:45 am
Are any of the other triggers working? I'll look into this, but I haven't seen or heard of any trigger issues?
Wed Jul 10, 2013 11:48 am
Dewster35 offline
Ben,
Any sort of idea when a manual triggered update location will be functional again?
Wed Jul 10, 2013 4:11 pm
Dewster35 wrote:
Ben,
I'm looking to possibly rewrite FMID, adding some new features from Indigo v6, and so forth.
I have been forced to scrap the idea of changing the FMID engine, but I believe I have made some changes that make the old one a little bit more reliable.
I'll be looking into this a little bit later this week.
- Ben
Thu Jul 11, 2013 4:46 am
Dewster35 offline
- Ben
No worries and certainly no rush. Was just curious if it was still in the plans to be done or if Apple locked something out on their end that wouldn't allow it to be fixed. Thanks for all the hard work!
Fri Jul 12, 2013 6:18 pm
ethank offline
I'll verify and I'm also going to try reverting to a prior version.
Sun Jul 14, 2013 10:42 am
ethank offline
Reverting it just kept saying "Registering iDevice" continually. The newest version works fine, but just doesn't do triggering.
Tue Jul 16, 2013 6:05 am
Dewster35 offline
Ben,
I want to thank you for creating this plugin. We had a false alarm this morning with our smoke detector. We have linked detectors but believe that the other detectors did not go off, but I use the insteon smoke bridge and send those type of emergency notifications with find my iDevices plugin. This way the phone can be in airplane mode and as long as I still have wifi turned on, I will get an audible alarm... so thank you. Your plugin definitely brings some peace of mind.
