Thermostat Enhancement Plugin
Thu Mar 20, 2014 5:29 pm
brentb offline
Re: Thermostat Enhancement Plugin
After some use now, my control page is showing a Daily Heat on Duration that keeps going up and up, and does not get reset. Its currently showing 3575 minutes of use today, and of course theres only 1440 minutes in a day. Is there something else I need to edit.
thanks
Brent
Mon May 05, 2014 12:33 pm
Catsailor offline
I have been running version 1.11 without any issue then it stopped working and when I reload I find this info in the log. I tried the 1.31 version and had the same error. I'm not clear if the issue is with the plugin or something else, any advice would be appreciated.
May 5, 2014 10:57:38 AM
Thermostat Enhancement Add-On Error Error in plugin execution startup:
File "plugin.py", line 61, in startup
File "/Library/Application Support/Perceptive Automation/Indigo 5/Plugins/Thermostat.indigoPlugin/Contents/Server Plugin/versioncheck.py", line 26, in VersionCheck
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/urllib2.py", line 124, in urlopen
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/urllib2.py", line 387, in open
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/urllib2.py", line 498, in http_response
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/urllib2.py", line 425, in error
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/urllib2.py", line 360, in _call_chain
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/urllib2.py", line 506, in http_error_default
<class 'urllib2.HTTPError'>: HTTP Error 500: Internal Server Error
Thermostat Enhancement Add-On Error exception in deviceStartComm(thremo mon): 'Plugin' object has no attribute 'thermo_index'
Sat May 31, 2014 9:37 pm
Catsailor offline
I was not able to determine the root cause but did find that removing the update checking functionality in the plugin.py file that I was able to get thermostat enhancement to work again.
Fri Jun 13, 2014 1:16 pm
CraigM offline
Is this Plugin still being supported?
My v1.11 broke somewhere in Indigo 6.x
Installed v1.31, still doesn't work.
Jun 13, 2014 11:57:18 AM
  File "plugin.py", line 64, in startup
  Thermostat Enhancement Add-On Error exception in deviceStartComm(HVAC Thermostat Enhancement [casita]): 'Plugin' object has no attribute 'thermo_index'
  Thermostat Enhancement Add-On Error exception in deviceStartComm(HVAC Thermostat Enhancement [house]): 'Plugin' object has no attribute 'thermo_index'
Why is the path to the /Indigo 5/ directory?
OS 10.8.4
Indigo 6.0.11
2441V Adapters
Venstar T1800's
Mon Jun 16, 2014 9:09 am
Catsailor offline
Not sure how it may be broke for you compared to what I had with v5 on 10.5 but you might try removing the update check like I ended up doing. Not elegant but seem to work for now.
Mon Jun 16, 2014 11:16 am
bschollnick2 offline
I just realized that when Matt & Jay revised the web site, it broke my feedly links.
Yes, it is supported.
I'm not sure why that would be happening, but it maybe the version check code.
Try https://dl.dropboxusercontent.com/u/241 ... 0v1.32.zip and let me know if that works better.
- Ben
for v5 - http://bit.ly/T6WBKu
Mon Jun 16, 2014 11:18 am
Brett, can your log around midnight? The plugin should on the next thermostat event after midnight, reset the counts.
Can you check to see if there is a error around that time?
This is one plugin which is next on my rewrite list, mainly to add some additional features (e.g. data reporting features).
- Ben
Mon Jun 16, 2014 3:51 pm
CraigM offline
- Ben
Installed 1.32
I get this at ever temp broadcast
Jun 16, 2014 2:40:38 PM
  Received INSTEON                "HVAC Thermostat [casita]" temperature changed to 87.0
  Thermostat Enhancement Add-On   HVAC Thermostat [casita] does not have a Thermostat Enhancement Monitor assigned to it.
This at disable
Disabling plugin "Thermostat Enhancement Add-On 1.32"
  Stopping plugin "Thermostat Enhancement Add-On 1.32" (pid 7881)
  Thermostat Enhancement Add-On Error exception in deviceStopComm(HVAC Thermostat Enhancement [casita]): 'pop(): dictionary is empty'
  Thermostat Enhancement Add-On Error exception in deviceStopComm(HVAC Thermostat Enhancement [house]): 'pop(): dictionary is empty'
  Stopped plugin "Thermostat Enhancement Add-On 1.32"
And this at enable
Enabling plugin "Thermostat Enhancement Add-On 1.32"
  Starting plugin "Thermostat Enhancement Add-On 1.32" (pid 7905)
  Started plugin "Thermostat Enhancement Add-On 1.32"
All states report 0
EDIT #1:
Ok, so the Disable/Enable seems to have kicked it into gear :)
- Log looks normal [single broadcasts w/ no error]
- Normal "system ran for xx" log entries
- Indigo device UI is not displaying:
CurrentCoolingSetpoint =0
CurrentHeatSetpoint =0
- I'm getting correct UI readings for:
CurrentTemperature
LastUpdated
Everything AC related
EDIT #2:
Now getting CurrentCoolingSetpoint reading [plugin doesn't read until there is a setpoint change]
So far all is good :D I'll see if it resets in 24 hrs.
Wed Jun 18, 2014 12:43 pm
CraigM offline
Unfortunately, it is not resetting or calculating the data.
I have two Venstars and each logs the same error at the time of 'new day reset' [first use of equipment the next day]
Thermostat Enhancement Add-On Error Error in plugin execution ServerReplacedElem:
  File "plugin.py", line 273, in deviceUpdated
  File "plugin.py", line 181, in test_state
<type 'exceptions.KeyError'>: key Last7Daysac not found in dict
Here is an example of todays first run:
Jun 18, 2014 11:00:00 AM
  Received INSTEON                "HVAC Thermostat [casita]" cool setpoint changed to 88.0
  Received INSTEON                "HVAC Thermostat [casita]" on (button 1)
  Thermostat Enhancement Add-On   Clearing Last Daily Runtime for ac.
  Thermostat Enhancement Add-On   The ac Daily Runtime for Tue Jun 17 21:33:52 2014 was 1052 minutes.
  Thermostat Enhancement Add-On   1052
Jun 18, 2014 11:10:04 AM
  Received INSTEON                "HVAC Thermostat [casita]" off (button 1)
  Thermostat Enhancement Add-On   The ac System ran for 819 minutes (Hours: 13.0)
As you can see the actual runtime was 10 minutes, but calculated as 819 minutes
The daily run [as displayed on my CP] started at 1052, which is grossly off, and is now 1871 [1052+819]
The next runs are as follows:
Jun 18, 2014 11:18:46 AM
Jun 18, 2014 11:24:07 AM
  Thermostat Enhancement Add-On   The ac System ran for 5 minutes (Hours: 0.0)
Jun 18, 2014 11:33:24 AM
Jun 18, 2014 11:38:30 AM
Wed Jun 18, 2014 4:27 pm
Okay, I will take a look, and see what I can find regarding this.
Wed Jun 18, 2014 10:34 pm
By the way with indigoplotD you can get a plot of the number of minutes "on":
select the thermostat , state: AC and measurement: "Count" - not average-- that will count the number of minutes "on" per Day and per Hour and per 5minute interval and make a plot out of it!
Karl.
Thu Jun 19, 2014 6:27 am
[/code]
Craig,
This error doesn't make sense.
The code in question is attempting to update the Last7Daysac state in the Thermostat Enhancement plugin.
Can you please check to see if that state exists in your TE plugin monitor. (You do have a monitor defined?)
- Benjamin
Thu Jun 19, 2014 12:17 pm
CraigM offline
bschollnick2 wrote:
Craig,
- Benjamin
I have:
2 thermostats
2 TE devices, each targeting a thermostat, all TE prefs are un-checked
Is there any significance to the error Last7Daysac and the TE Last7DaysAC ?
Thu Jun 19, 2014 1:00 pm
CraigM wrote:
Quite frankly. Yes, being a dictionary, it is case sensitive, but I don't see why I wouldn't be seeing that on my version.
I will be testing this later today, and seeing what might need to be done.
- Ben
Fri Jun 20, 2014 9:24 pm
Drop me a line at Benjamin DOT schollnick DOT net. I have a version for testing, that should resolve this issue.
- Benjamin
