Log Viewer
Tue Jan 21, 2014 10:41 pm
automaton offline
Log Viewer
Somewhere between Indigo 6.05 and 6.09 my log viewer stopped working. The errors are shown below. Any idea how to revive it?
  WebServer                       internal server error "http://xxxx.xxxx.com:8000/Eventlog/" from 192.168.241.36
  WebServer
Request Headers:
  HOST: xxxx.xxxx.com:8000
  ACCEPT: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
  USER-AGENT: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_9_1) AppleWebKit/537.73.11 (KHTML, like Gecko) Version/7.0.1 Safari/537.73.11
  CONNECTION: keep-alive
  Remote-Addr: 192.168.241.36
  ACCEPT-LANGUAGE: en-us
  ACCEPT-ENCODING: gzip, deflate
  File "/Library/Application Support/Perceptive Automation/Indigo 6/IndigoWebServer/cherrypy/_cprequest.py", line 609, in respond
    cherrypy.response.body = self.handler()
  File "/Library/Application Support/Perceptive Automation/Indigo 6/IndigoWebServer/cherrypy/_cpdispatch.py", line 25, in __call__
    return self.callable(*self.args, **self.kwargs)
  File "/Library/Application Support/Perceptive Automation/Indigo 6/IndigoWebServer/plugins/Eventlog/reqhandler.py", line 267, in index
    html_elems.append("      </table>\n")
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 20: ordinal not in range(128)
  WebServer                       undefined page requested "http://xxxx.xxxx.com:8000/Eventlog/css/global4.css" from 192.168.241.36
  WebServer                       undefined page requested "http://xxxx.xxxx.com:8000/Eventlog/css/indigo4.css" from 192.168.241.36
Wed Jan 22, 2014 10:49 am
Re: Log Viewer
It looks like there's a non-ascii character in your log which the plugin isn't handling correctly.
Thu Jan 23, 2014 6:45 pm
automaton offline
Re: Log Viewer
Weird, it has healed itself, which supports your theory. What would generate a non-ascii character in the log?
Thu Jan 23, 2014 6:59 pm
Re: Log Viewer
Pretty much any script or plugin could. A device or variable name that has unicode characters in it.
Thu Jan 23, 2014 7:33 pm
Re: Log Viewer
Note the Event Log plugin could probably be modified to handle the unicode character correctly. It might just need to use a unicode string (u"") instead of an ascii string ("") somewhere. I'm not familiar with the code though and it isn't obvious from the stack trace in your event log as to where the problem is specifically.
Wed Jun 18, 2014 9:57 am
bschollnick2 offline
Re: Log Viewer
Unicode can be a pain. I'm having issues with it with some Image gallery software that I'm working on.
The true fix is Python v3 (completely Unicode based), but for v2 the unidecode library is excellent for mapping unicode to ascii.
That being said, I am starting to rework or re-evaluate some of the older plugins, and decide what I need to do to update them.
By the way, I just realized that my RSS feeds were killed when you migrated to the newer version of the forum software.
I would suggest that you point out somewhere that the complete RSS feed is available from the pull down. I was concerned that I would have to add 30+ feeds so that I could monitor the forums I need to view.
for v5 - http://bit.ly/T6WBKu
Mon Sep 15, 2014 2:02 pm
Re: Log Viewer
Does this still work for 6.0.14?
I copied it to /Library/Application Support/Perceptive Automation/Indigo 6/IndigoWebServer/plugins/Eventlog and reloaded Indigo.
When I browse to http://192.168.3.2:8176/Eventlog/ I get 'internal server error' and nothing else.
Just noticed this in the logs... :oops:
WebServer                       internal server error "http://192.168.3.2:8176/Eventlog/" from 192.168.3.2
  WebServer
Request Headers:
  AUTHORIZATION: Digest username="removed", realm="Indigo Control Server", nonce="removed", uri="/Eventlog/", response="removed", algorithm="MD5", cnonce="removed", nc=00000001, qop="auth"
  HOST: 192.168.3.2:8176
  USER-AGENT: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_9_4) AppleWebKit/537.78.2 (KHTML, like Gecko) Version/7.0.6 Safari/537.78.2
  Remote-Addr: 192.168.3.2
  File "/Library/Application Support/Perceptive Automation/Indigo 6/IndigoWebServer/plugins/Eventlog/reqhandler.py", line 210, in index
    csv_data, tag_data, dates = _read_indigo_log_file(r'%s' % filename, csv_data, tag_data, dates)
  File "/Library/Application Support/Perceptive Automation/Indigo 6/IndigoWebServer/plugins/Eventlog/reqhandler.py", line 66, in _read_indigo_log_file
    for log_line in csv_file:
Error: line contains NULL byte
  WebServer                       undefined page requested "http://192.168.3.2:8176/Eventlog/css/indigo4.css" from 192.168.3.2
  WebServer                       undefined page requested "http://192.168.3.2:8176/Eventlog/css/global4.css" from 192.168.3.2
Peter
Tue Sep 16, 2014 12:54 pm
Re: Log Viewer
It should. I haven't checked recently but I did update it for Indigo v5/6 a while back.
Check to see that you are using the latest version v1.57a - https://dl.dropboxusercontent.com/u/241 ... g_157a.zip
WebServer undefined page requested "http://192.168.3.2:8176/Eventlog/css/global4.css" from 192.168.3.2[/code]
This indicates that there is a NULL byte, that maybe in the log file. That could be due to a plugin, or device name, or something else? Do you have any device names that are not standard ASCII?
- Benjamin
Tue Sep 16, 2014 12:58 pm
Re: Log Viewer
- Benjamin
Not to my knowledge; I'm using all English ones and nothing fancy.
I'll have a look - I spotted that error after I posted but didn't have time to look through at that point.
Peter
Mon Nov 10, 2014 1:28 pm
DVDDave offline
Re: Log Viewer
Wow, this log viewer works spectacularly well. I can't believe it took me this long to find it.
A couple of minor notes:
I have been working with the Indigo developers to fix a problem associated with changing the Indigo root that prevented the Log Viewer from working. Matt sent me a test file that seems to have fixed it. I suspect he will issue an update shortly.
Also, one completely minor problem with the Log Viewer is that the number of days to show the log is off by one; e.g., asking for 3 days only shows 2. I have not looked through this whole thread so my apologies if this has been discussed before. Aside from that, it seems to work perfectly with Indigo 6.
--Dave
Tue Nov 11, 2014 5:50 am
Re: Log Viewer
Hi Dave -
Were you receiving an "Internal Server Error" message? I installed this plugin, but am receiving the same message that Peter is receiving above.
Dave
Tue Nov 11, 2014 8:37 am
DVDDave offline
Re: Log Viewer
Dave,
No, the problem was that the link to the log viewer did not work since I had changed the Indigo root. See viewtopic.php?f=108&t=12855
I have not seen the error noted by Peter.
--Dave
Tue Nov 11, 2014 9:55 am
Re: Log Viewer
DVDDave wrote:
Dave,
--Dave
Thanks Dave.
Hopefully, Peter and Ben are monitoring the thread and would be able to provide some insights.
Cheers,
Dave
Tue Nov 11, 2014 11:17 am
Re: Log Viewer
I never actually followed up on this; I'll try and look in the next couple of days but it might not be tonight.
Tue Nov 11, 2014 12:22 pm
Re: Log Viewer
Thanks very much.
Cheers,
Dave
