hamw wrote:Will Switchboard allow monitoring of multiple variables to execute single trigger, rather than have to write a series of triggers for each variable? How would I set that up?
Repost.
hamw wrote:In my WHA setup I have a single iPhone page that can change between iTunes and Pandora players. The buttons will swap on the page for whichever one is playing to reflect the appropriate playlists. In order to do this I need to know if Pandora or iTunes are on, off, playing or paused. A change in their variables will trigger the same script that changes the page buttons.
terrydew wrote:Has version 61 been released yet?
Sep 3, 2012 2:31:07 PM
Switchboard Error Error in plugin execution GetUiDynamicList:
<type 'exceptions.TypeError'>: return_devices_in_zone() takes exactly 2 arguments (5 given)
DU Lou wrote:Hi Benjamin.
Just Dl'd SB 7.0 and Indigo shows (after a server restart) the plugin started without an issue. However when I attempt to create a new device, the "Configured Device Monitored Device Group" gives me the following error in the Zones window below.
Here is a copy of the log as well:
- Code: Select all
bschollnick2 wrote:DU Lou wrote:Hi Benjamin.
- Code: Select all
There appears to have been a small hiccup, but I can't explain your error message. Instead I found a different one...
Please try this file...
https://dl.dropbox.com/u/241415/Switchb ... 0v0.71.zip
DU Lou wrote:Hmmm No change with .71 Ben. I received the same event log entry and window error. The even log also noted "Plugin "Switchboard 0.71" started" just to make sure I didn't accidentally place .70 back in the plugin folder
As a test I reinstalled .56 and was able to create a monitored group without issue. Oh I am running Mountain Lion now as well. Not sure if that would make a difference. Let me know if you need any further info from me..
