Battery & UPS Monitor plugin.
Tue Jan 28, 2020 7:08 am
Re: Battery & UPS Monitor plugin.
I posted a link to a fixed version of this plugin in another thread.
https://github.com/FlyingDiver/Indigo-U ... /tag/1.0.5
Tue Jan 28, 2020 7:44 am
McJohn offline
Thanks for the quick response and the update!
- Maybe it's an idea to post this version into the Plugin Store?
- There is something strange going on with the version numbers and the upgrade message from Indigo.
We have version 1.03. (Installed ~ 2014)
Logical is your number 1.05 a higher number (learned at school :D )
But the message in Indigo is:
Screenshot 2020-01-28 at 14.39.33.png (52.25 KiB) Viewed 853 times
Tue Jan 28, 2020 8:17 am
I'll have to talk to Matt and Jay about replacing the store version. It's not my plugin, so I can't just update the existing one.
I also have no idea why you're getting that error. The version number increment seems to be correct.
Tue Jan 28, 2020 11:13 am
McJohn offline
Just did some different tests: without and with power available.
Works perfect and Triggers are firing smoothly without any errors anymore!
You did a good job and it's definitely plugin store ready!
Thanks! :D
Tue Sep 08, 2020 3:51 pm
agame offline
I'm not sure if this is the right location for this post but it is UPS related.
Currently experiencing a lot of storms (and associated power outages) so have added a UPS that had fallen into disuse to a Mac mini /Indigo server. Running Catalina.
But whereas after a 'dirty' shutdown the Mac will auto restart when power returns; after a 'clean' (UPS-initiated) shutdown, it requires a manual reboot. Obviously it will ultimately return after the daily restart schedule, but thats less than ideal.
Is there a way to overcome this (other than allowing a dirty shutdown?).
Tue Sep 08, 2020 3:56 pm
Not that I know of. I've done some searching on the topic, and never came up with a solution I thought was reliable.
Get a bigger UPS. :)
Tue Sep 08, 2020 4:00 pm
agame offline
damn!
ha! I actually bought a generator yesterday, that should give a few more hours...
Tue Sep 08, 2020 11:29 pm
2 options:
1. in system prefs set an auto start - that is a fixed time, but you can also set it to eg 1 hours into the future in command line:
use: where the time is 1 hour into the future, run this every 5 minutes
pmset schedule wakeorpoweron "09/08/20 20:00:00"
then when shut down it will try to wake up one hour later
also try acwake, womp
2. set dirty bit: shutdown -u, but that requires to have power off within minutes after successful shutdown, then when UPS power comes back it will restart
not perfect but ..
check out "man pmset" on your mac terminal
But with corona lasting another 6+ months I am not leaving the house any time soon. And we had no long power interruptions in the last year. Only a few secs
==> This is not a priority right now
