Just installed 2 fresh relays with a new Shelly web account. Everything working within Shelly Web apps and can access and control the devices via internet and http locally. Installed the Shelly Plugin and everything seems to configure ok with the devices. However commands to control the devices and or status are not working for me via the plugin and I am seeing these kind of errors in the logs:
2023-06-25 14:27:09 Connection: /usr/bin/curl -m 10 --globoff 'http://192.168.20.143:80/settings'
2023-06-25 14:27:09 Shelly curl response from 192.168.20.143 no json object returned: >Not Found<> % Total % Received % Xferd Average Speed T<
2023-06-25 14:27:09 shellyPollerThread last querry were not successful wait, then try again; ip:192.168.20.143
2023-06-25 14:27:09 sbin/ping -c 1 -W 40 -o 192.168.20.143 ret-code: 0
2023-06-25 14:27:09 getJsonFromDevices: ip:192.168.20.143 page:status
2023-06-25 14:27:09 Connection: /usr/bin/curl -m 10 --globoff 'http://192.168.20.143:80/status'
2023-06-25 14:27:22 sbin/ping -c 1 -W 40 -o 192.168.20.143 ret-code: 0
2023-06-25 14:27:22 getJsonFromDevices: ip:192.168.20.143 page:settings
Have tried different “curl / python” request options in the plugin configuration but similar or same errors regardless of the type selected.
Also notice on http request to the devices themselves, that I can get to the interface with the ip alone, but the http://192.168.20.143/settings and http://192.168.20.143/status URL’s return Not Found through the UI. Does this imply these newer devices / firmware may not be supported by the plugin commands?
Curl to the devices with the full settings or status URLs seem to return the same Not Found.
Anyone have into insights as to what my issue many be?
