Shelly Dimmer 2
Sat May 01, 2021 4:04 am
Coolcaper offline
Shelly Dimmer 2
Hi Karl,
Thanks for the plug in.
I've got a Shelly Dimmer 2 ( https://shelly.cloud/products/shelly-di ... ontroller/ ) that I am trying to add but get the error:
shellyDirect Error Line 2832 has error=u'shellydimmer2'
shellyDirect Warning ip# 10.0.5.30 can not create dev with type: shellydimmer2
I presume its because its not defined in your plugin? If so, could you let me know if you require anything specific from me for you to please add this device to the plugin?
Sat May 01, 2021 6:21 am
Re: Shelly Dimmer 2
I need to add that model to the plugin
I am busy this weekend. Will try early next week.
You could send me the output of
ip#/status
And
Ip#/settings
Using safari
Sat May 01, 2021 8:00 pm
Coolcaper offline
Re: Shelly Dimmer 2
Thanks Karl.
This is from 'status':
{"wifi_sta":{"connected":true,"ssid":"XXXX","ip":"10.0.5.30","rssi":-62},"cloud":{"enabled":true,"connected":true},"mqtt":{"connected":false},"time":"09:50","unixtime":1619920212,"serial":1345,"has_update":false,"mac":"XXXXXXXXXX","cfg_changed_cnt":12,"actions_stats":{"skipped":0},"lights":[{"ison":false,"source":"http","has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"mode":"white","brightness":40}],"meters":[{"power":0.00,"overpower":0.00,"is_valid":true, "timestamp":1619949012,"counters":[0.000, 0.000, 0.000],"total":1908}],"inputs":[{"input":0,"event":"","event_cnt":10},{"input":0,"event":"","event_cnt":6}],"tmp":{"tC":47.14,"tF":116.85, "is_valid":true},"calibrated":true,"calib_progress":100,"calib_status":0,"calib_running":0,"wire_mode":0,"forced_neutral":false,"overtemperature":false,"loaderror":0,"overpower":false,"debug":0,"update":{"status":"idle","has_update":false,"new_version":"20210415-131442/v1.10.3-g23074d0","old_version":"20210415-131442/v1.10.3-g23074d0"},"ram_total":48216,"ram_free":35292,"fs_size":233681,"fs_free":118974,"uptime":66908}
This is from 'settings':
{"device":{"type":"SHDM-2","mac":"XXXXXXXX","hostname":"shellydimmer2-XXXXXXX","num_inputs":2,"num_outputs":1,"num_meters":1},"wifi_ap":{"enabled":false,"ssid":"shellydimmer2-XXXXXXXX","key":""},"wifi_sta":{"enabled":true,"ssid":"XXXXXX","ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"wifi_sta1":{"enabled":false,"ssid":null,"ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"ap_roaming":{"enabled":false,"threshold":-70},"mqtt": {"enable":false,"server":"192.168.33.3:1883","user":"","id":"shellydimmer2-XXXXXXXX","reconnect_timeout_max":60.000000,"reconnect_timeout_min":2.000000,"clean_session":true,"keep_alive":60,"max_qos":0,"retain":false,"update_period":30},"coiot": {"enabled":true,"update_period":15,"peer":""},"sntp":{"server":"time.google.com","enabled":true},"login":{"enabled":false,"unprotected":false,"username":"admin"},"pin_code":"","name":"XXXXXXXX","fw":"20210415-131442/v1.10.3-g23074d0","factory_reset_from_switch":true,"discoverable":true,"build_info":{"build_id":"20210415-131442/v1.10.3-g23074d0","build_timestamp":"2021-04-15T13:14:42Z","build_version":"1.0"},"cloud":{"enabled":true,"connected":true},"timezone":"Australia/XXXXXX","lat":-XXXXXXX,"lng":XXXXXXX,"tzautodetect":false,"tz_utc_offset":28800,"tz_dst":false,"tz_dst_auto":false,"time":"09:53","unixtime":1619920407,"led_status_disable":false,"debug_enable":false,"allow_cross_origin":false,"actions":{"active":false,"names":["btn1_on_url","btn1_off_url","btn1_longpush_url","btn1_shortpush_url","btn2_on_url","btn2_off_url","btn2_longpush_url","btn2_shortpush_url","out_on_url","out_off_url"]},"hwinfo":{"hw_revision":"prod-20200629","batch_id":1},"mode":"white","pulse_mode":2,"pulse_mode_detected":1,"pulse_mode_rebooted":0,"load_autodetect":1,"calibrated":true,"transition":1000,"fade_rate":3,"min_brightness":0,"zcross_debounce":100,"bypass":false,"lights":[{"name":"","ison":false,"default_state":"last","auto_on":0.00,"auto_off":0.00,"schedule":false,"schedule_rules":[],"btn_type":"dual_button","btn_debounce":80,"swap_inputs":0}],"night_mode":{"enabled":false, "start_time":"00:00", "end_time":"00:00", "brightness":0},"warm_up": {"enabled":0, "brightness":100, "time":50}}
Sat May 01, 2021 8:01 pm
Re: Shelly Dimmer 2
Ok, the name is dimmer2. Not dimmer
The functionality looks the same. That should be easy.
Sat May 01, 2021 10:18 pm
Re: Shelly Dimmer 2
try version 7.14.35
preliminary support for dimmer2 devices
Sun May 02, 2021 3:48 am
Coolcaper offline
Re: Shelly Dimmer 2
Seems to be working fine so far.
Thanks for the quick update.
