SHELLY plugin
Wed Dec 27, 2023 12:57 pm
mpleeds offline
Re: SHELLY plugin
Hi Karl, enabling the Button Switched On URL option worked - input on/off state is instantly reported back to Indigo - no polling required. I'm now able to control the Shelly relay outputs while using the switch (in detached mode) to independently monitor garage door state. Thanks for your detailed instructions, Merrill
Thu Dec 28, 2023 11:00 am
Re: SHELLY plugin
You can use menu push … to set proper values in the Shelly devices. It normally should do it automatically at creation of device.
Thu Dec 28, 2023 12:32 pm
mpleeds offline
Re: SHELLY plugin
I'm not sure what your referring to by "Menu Push" - could it be the "Push Setting to Shelly Device" (see screenshot). If so, how should the "message from Plugin" field be completed?
Shelly Push.png (170.58 KiB) Viewed 336 times
Thu Dec 28, 2023 12:54 pm
Re: SHELLY plugin
Yes that’s it.
and message from plugin will tell you the response from the plugin
